Intuitive idea for chaotic light statistics?
In summary, the discussion revolves around the statistics of chaotic light and the value of g(2) for this type of light. The definition of g(2) and its relation to the photon number variation is explained, leading to the conclusion that for thermal light, g(2)=2. The origin of intensity fluctuations in chaotic light is attributed to the physics of random walks, and the coherence time is dependent on the phase jump per step. The physical processes that induce these phase jumps are discussed, with the conclusion that they are related to the spectral filtering of the light source.
Affcr
Does anyone have an intuitive idea for the statistics of chaotic light? I can understand that the power fluctuations in this kind of light can give rise to a second order autocorrelation parameter g(2) higher than 1. However I can not see why the value for this parameter should be g(2)=2. Does anyone have an intuitive explanation for this value and why it is not higher or lower?
There is very little intuition in there. Just some math. Consider the definition of g(2), which roughly translates into a constant and the photon number variation divided by the squared mean. For thermal light these two are pretty much equal, so you will get a value of two.
To be exact:
[itex]g^{(2)}(0)=\frac{\langle : n^2: \rangle}{\langle n \rangle^2}[/itex]
The double stops denote normal ordering which ensures that the detection of the first photon reduces the photon number by 1. That leaves you with:
[itex]g^{(2)}(0)=\frac{\langle n (n-1) \rangle}{\langle n \rangle^2}[/itex]
Of course you can represent the instantaneous photon number n as the sum of the mean [itex]\langle n \rangle[/itex] and some fluctuation [itex]\delta[/itex] about the mean. So you get:
[itex]g^{(2)}(0)=\frac{\langle (\langle n \rangle +\delta) (\langle n \rangle+\delta-1) \rangle}{\langle n \rangle^2}[/itex]
All terms linear in [itex]\delta[/itex] must of course vanish when taking the expectation value, so you are left with:
[itex]g^{(2)}(0)=\frac{\langle n^2 \rangle - \langle n \rangle + \delta^2}{\langle n \rangle^2}=1-\frac{1}{\langle n \rangle}+\frac{\delta^2}{\langle n \rangle^2}[/itex]
The [itex]\delta^2[/itex] term is proportional to the photon number variance. For thermal light, this is [itex]\langle n \rangle^2 +\langle n \rangle[/itex], which just leaves you with two.
Likes vanhees71 and Affcr
Thank you for the explanation, Cthugha. This makes me understant better the concep of chaotic light and why [itex]g^{(2)}(0)=2[/itex], but leads me to further doubts which I would appreciate if you know and can tell me the answer:
Why is the photon number variance of chaotic light [itex]\langle n \rangle^2 +\langle n \rangle[/itex] ? Is this expression just based on experimental evidence?
What is the origin of the intensity fluctuations?
What does the coherence time of cahotic light depend on? Do you know about any experiment in which they can change this time by modifying any property of the source?
This result is not just based on experiments. You can simulate it yourself, if you have basic knowledge of any programming language or Matlab or something like that. Chaotic light is basically about the physics of the random walk. As a toy model a thermal light source can be described as a large number of harmonic oscillators, each with the same amplitude. The total amplitude is given by vectorial addition of all of these amplitudes. The total intensity is given by the square of the amplitude. Now you set some initial phase for each of these oscillators and simulate the time evolution of the system in discrete steps. You set a small maximal possible phase jump [itex]\phi_m[/itex] per discrete time step and in each time step you create a different random number for each of the many oscillators such that each oscillator undergoes a phase jump somewhere between [itex]- \phi_m[/itex] and [itex]+\phi_m[/itex]. Most of the time all of the fields will cancel and you get small intensity. Sometimes the fields will add up to a large amplitude and you will get huge intensity. If you plot the intensity over time, you will get fluctuations that have the variance of thermal light with [itex]\langle n \rangle[/itex] proportional to the number of oscillators you use.
The coherence time depends on the phase jump per step that you use. In experiments you can change this easily. The decay of coherence is proportional to the Fourier transform of the power spectrum of your light field. In easy terms: If you filter your light source spectrally and get a narrower spectrum, you will get longer coherence time.
Likes Affcr and vanhees71
Thanks again, now I get some intution about the process. Let me just ask a last question. Do you know which can be the physical processes that induce these phase jumps and why should they be small? If they were related to spontaneous emission I would expect the phase jumps to have any value between 0 and [itex]2\pi[/itex], so if it is no like this I guess it has to be related to another phenomenon.
Related to Intuitive idea for chaotic light statistics?
1. What is chaos in light statistics?
Chaos in light statistics refers to the seemingly random and unpredictable behavior of light waves. This can occur when light is scattered or reflected multiple times, leading to a complex interference pattern that is difficult to predict or control.
2. How does chaos affect light propagation?
Chaos can significantly impact the propagation of light, causing it to deviate from its original path and create a distorted image. This can be observed in natural phenomena such as the twinkling of stars or in man-made systems like fiber optic cables.
3. What is the role of chaos in laser beams?
Chaos plays a crucial role in laser beams, as it is responsible for the formation of speckle patterns. These patterns arise from the interference of light waves that have undergone chaotic scattering, and can have important implications for applications such as holography and imaging.
4. How can chaotic light statistics be studied?
There are various experimental and theoretical methods for studying chaotic light statistics. These include using numerical simulations, analyzing statistical properties of light intensity, and measuring the effects of chaotic scattering on light propagation.
5. What are the potential applications of understanding chaotic light statistics?
Understanding chaotic light statistics has a wide range of applications, including in communication systems, imaging techniques, and optical sensing. It can also provide insights into fundamental physical phenomena, such as wave-particle duality and quantum chaos.
