Why Is the Invariant Interval True for All Values of s?
In summary, the invariant interval is a fundamental concept in the theory of relativity, stating that the spacetime interval between two events remains constant for all observers, regardless of their relative motion. This invariance arises from the structure of spacetime in Minkowski geometry, where the interval is calculated using the time and spatial coordinates of events. The mathematical formulation shows that, while individual time and space measurements may vary for different observers, the overall spacetime interval, defined as the square root of the difference between squared time and spatial differences, remains unchanged. This principle is essential for the consistency of physical laws across different reference frames and underpins the relativistic effects observed in high-speed scenarios.
PreposterousUniverse
31
If we use a light pulse that is emitted at A and absorbed at B. The spacetime interval between these two events are s'=s=0 in both frames of reference. But how does this invariance between s and s' extend to cases where s is not zero? Then we cannot measure the distance between the events using a light pulse and use the invariance of the speed of light to argue that s=s'. So how should we reason then? All explanations I have found just postulates that it is true in cases where s is some other value other than zero, but does not explain why it is true for all values of s.
Which frames of reference? You haven't described any.
It works the same. The spacetime interval is always an invariant.
We aren't using the invariance of the speed of light to argue that s = s'. The interval is invariant because it is an invariant; it's geometry.
Where have you looked?
Two inertial frames of reference. "The interval is invariant because it is invariant". What kind of explanation is that? Then why did we use the invariance of the speed of light to prove that s=s' in the case when s=0? Would it not also be true because an invariant is an invariant because of geometry then?
Why is Pythagoras’ theorem true?
The answer is the same: because that is how geometry of the underlying space works. The only difference is Euclidean vs Minkowski space.
Likes PhDeezNutz
When you ask how to get somewhere, the answer very much depends where you are starting from.
One obvious way to show the invariance of the interval is to write out the expression for ##\Delta s^2## and plug in the Lorentz transforms to eliminate the unprimed coordinates. But that might be a circular argument, depending on how you chose to derive the Lorentz transforms.
Likes Dale
Yes of course, that would be trivial. But circular reasoning as I see it, because I want to use the invariance of the interval to derive the Lorentz transformations. The case s=s'=0 for a light pulse traveling between point A and B follows from the principle that the speed of light is invariant in all inertial frames. But why does it extend to the case when s is not equal to zero?
We haven't made any assumptions about the underlying geometry. We have only assumed that the speed of light is invariant. From this assumption we can prove that s=s'=0 for two event separated by a light pulse. But how does it extend to the case when s differs from 0?
Who are ”we”? You need to be more specific about your assumptions if you are just going to randomly reject replies. The underlying space in SR is Minkowski space.
Likes Dale
Ok.
A geometric one.
We didn't, as I have already told you. If you think "we" did, you need to give a specific reference that supports your claim.
No "also" about it; it is true, for any interval, whether s = 0 or not, because of geometry.
You can do that regardless of whether the interval is null. It is an easily demonstrated mathematical fact that the Lorentz transformations are the transformations that leave the Minkowski interval invariant in the general case, for any interval.
This is covered in any SR textbook. The relevant chapter of Morin's book is free online:
https://scholar.harvard.edu/files/david-morin/files/cmchap11.pdf
This follows the traditional approach:
Postulates -> Lorentz Transformation -> Invariant Interval
I thought I was clear. We are not assuming the underlying space is Minkowski, we are going to derive it. We can derive from the relation s=s' which states that (cdt)^2-(dx)^2 = (cdt')^2 - (dx')^2. We can prove that this relation holds when (cdt)^2-(dx)^2 = (cdt')^2 - (dx')^2 = 0 by considering two events A and B separated by a light pulse and using the invariance of the speed of light. But we haven't proved that s=s' in general. We must show this before we can derive the general form of the transformations.
But where did you get that relation from? From the Minkowski metric, i.e., from the fact that the underlying space is Minkowski.
Which already assumes that the underlying space is Minkowski; otherwise the equation you are using for the interval is not correct.
Where are you getting all this from?
No we are not assuming a Minkowski metric or any other metric. (cdt)^2 - (dx)^2 is just a quantity that we are calculating. The space could be cartesian or any other space, we can calculate any quantity we want from the coordinates between two point in the space. But we have showed using the invariance of the speed of light that for two event connected by a light pulse, this particular quantity is invariant and equal to zero. But we haven't showed that it is invariant for other values. If we can do that, then we can derive the general transformations.
  • Skeptical
Likes Sagittarius A-Star, Dale and Motore
No you haven't, because you can't just assume that the coordinates of two events connected by a light pulse have the relationship you wrote down. You have to calculate that relationship from the metric--and unless the metric is the Minkowski metric, the relationship won't be the one you wrote down.
At this point I am closing this thread since you have given no references to back up any of your claims and what you are posting looks like personal speculation, which is off limits here. If you have an actual reference, you can PM me and I can review it to see if it's worth reopening the thread to discuss it.
