B Invariant under rotation: Banal, obvious, or noteworthy?
The discussion explores the relationship between Cartesian coordinates and spheres, particularly how the coordinates of a point change under rotation while the distance from the origin remains constant. It highlights that the surface area of a circumscribing sphere is invariant under rotation, unlike that of a cuboid. The conversation raises questions about whether this relationship is common knowledge or if it has been overlooked in mathematical literature. Participants express uncertainty about the triviality of the concept and seek references that discuss this geometric relationship explicitly. The discussion emphasizes the need for educational resources to address these geometric principles more clearly.
Trysse
TL;DR Summary
You can find the coordinates of a given point P in a Cartesian coordinate system, by imagining a sphere on which the point P and the origin are antipodal. The points where the axes intersect this sphere mark the coordinates of the point. Is this relationship noteworthy or banal?
Given a cartesian coordinate system with a fixed point of origin and three axes, it is a fact, that the coordinates of a point P change, when the coordinate system is rotated around its point of origin. The distance between the origin and point P is of course unaffected by such a rotation. What is consequently unaffected is the square over the distance ##OP##.
Going back to the theorem of Pythagoras, the squares of each of the coordinates added together is equal to the square over the distance ##OP##. This is common knowledge.
However, there is a different way to think about the separation (respectively the relation) between the point of origin ##O## and the point ##P##. Imagine the points ##O## and ##P## to be antipodal points of a sphere. The surface area of this sphere is related to the distance between the two points by the ratio
$$A=(PO)^2*\pi$$
This is not too remarkable. However, what I found remarkable is the fact, how each of the three cartesian axes intersects with the sphere in two points. One of the points does not offer any additional information: This point is ##O##, the origin of the coordinate system. However, the other point in which the axis intersects the sphere is the coordinate of the point on this axis.
For visualization, you can look here: https://www.geogebra.org/classic/gwas9fwd
Once this relation between the sphere and the coordinates is pointed out, it becomes obvious. In the “classic” introduction of the cartesian coordinate system, the three coordinates can be seen as describing a rectangular cuboid.
Point ##O## is one of the apices of the cuboid and point ##P## is the apex that lies diagonally across the cuboid. The sphere on which the points O and P are antipodal is the sphere that circumscribes this cuboid.
So why did I find it noteworthy?
  • The surface area of the cuboid is not invariant under the rotation of the coordinate axes. However, the sphere (and its surface area) does not change as I rotate the coordinate system. So every point in space can be described by a sphere on which point O is antipodal to the described point.
    Every sphere can be described by four points. If I use the points where the Cartesian axes intersect with the sphere, these four points are: The origin ##O= (0,0,0)## and the three points ##(x,0,0)##, ##(0,y,0)##, and ##(0,0,z)##.
  • To know the coordinates of a given point, I would normally first drop a perpendicular line from the point to the plane described by two axes and then I draw a second perpendicular line on that plane to the axis of which I want to know the coordinate.
    If I consider the sphere, I must only look, at where the axes intersect with the sphere.
    If I think of the sphere as the naturals shape in space, then this way of thinking about the coordinates might be considered more natural than the cuboid. It is a “natural” way to determine each of the coordinates (i.e. the distance along the x-, y- and z-axis not the numerical values).
In a plane, this relationship can be shown with a circle instead of a sphere.
I have noticed this relation between the cartesian coordinates, the two antipodal points and the sphere while considering the cartesian coordinate system and the Theorem of Pythagoras in three dimensions. After I noticed this relationship, I have tried to find any mention of it in the literature. However, I was unable to find it anywhere. So, the question to myself was: Is this relation so obvious and banal that it is not worth mentioning, or has it been mentioned anywhere and I just did not find it?
Consequently, my questions to you are: Can you point me to a book in which this relation is mentioned? If you don’t know of any book, were you aware of this relationship before you read this post? If you were not aware, do you find it noteworthy or banal? If you were aware, did you ever wonder, why it is not commonly mentioned?
Mathematics news on Phys.org
I think it's pretty trivial. Works in 2d as well
high school books on math should treat this adequately ...
I don't know if it is trivial, because I am hopeless when it comes to proofs. However, I am not so sure if it is obvious. Many geometric relations are obvious once you know them. So maybe I should rephrase my question: "Is it common knowledge?"
What do I mean by this: If I ask random people, what they can say about a right-angled triangle I guess many will immediately say something related to the theorem of Pythagoras. They will do so because Pythagoras's Theorem is common knowledge However, what will they say, when you ask them to say something about a circle in a coordinate system where the origin and some point ##P=(x,y)## are antipodal? I am not sure how many people will answer that such a circle intersects the axes in the points ##(x,0)## and ##(0,y)##.
But do you know of any math book that has a statement like: "If you consider the points ##O=(0,0,0)## and ##P=((x,y,z)## in a Cartesian coordinates system to be the antipodal points on a sphere than this sphere will intersect the x-, y-, and z-axis in the points ##(x,0,0)##, ##(0,y,0)## and ((0,0,z)## regardless of the orientation of the axes"? Or something in that direction that makes this relationship obvious for somebody who is not aware of this fact.
I can of course say, that this fact can be derived from other facts (e.g. considering the equation of the sphere). However, the question is, how many people will consider these things beyond what is written in a book? As long as it is not explicitly stated, that knowledge is contingent.
What I have seen about how coordinate systems are treated in textbooks it is mainly about how to use them and not how they "work".
I guess the intention of this question is to find a book in which this relationship is mentioned to give me a feeling, that somebody else found these thoughts relevant enough to consider and write down.
And as I think about it, I have come to a "practical" application: Imagine I have a rotating coordinate system and I want to keep track of the coordinates of points that are not rotating. This can be nicely visualized:
https://www.geogebra.org/classic/aepr7aqn
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
