Inverse function of the Nyquist-Shannon sampling theorem
In summary, the Nyquist-Shannon sampling theorem states that if you take a finite number of samples of a signal, you can reconstruct the signal by averaging the values of those samples. The theorem is applicable to signals that are not multivalued in time, and is only approximate for short sequences.
d2x
I'm currently carrying out an analysis on waveforms produced by a particular particle detector. The Nyquist-Shannon sampling theorem has been very useful for making an interpolation over the original sample points obtained from the oscilloscope. The theorem (for a finite set of samples) is given by:
$$x(t) = \sum_{n=1}^{N} x(nT)sinc\bigg(\frac{t-nT}{T}\bigg)$$
It seems that it would also be very useful to have a function that can do the opposite operation (i.e. you give it a value of x and get t):
$$t(x)$$
I'm wondering whether or not this can be easily achieved. I'm not sure where to start due to the sum on the RHS. Any help or tips on how to start would be greatly appreciated.
Hmm. I'm not sure about the applicability of "reversing interpolation" and definitely have no immediate solution to the math problem. But. There may be some help available from @StoneTemplePython or @Stephen Tashi
Any signal of interest is likely to be multi-valued as a function of time (think about a sine wave, for example, which takes on the same value at many different times). Since these functions are not one to one across the two domains, your expression cannot be inverted uniquely. A waveform that is not multivalued in time, on the other hand, must be constant or monotonically increasing or decreasing, and is therefore of little interest to real detection problems.
As an aside, note that the sinc function used for interpolation has an infinite extent. (I think that Shannon considered the problem of exactly reconstructing an infinite waveform.) As a result, its use to reconstruct any finite length sampled series is only approximate. The approximation is worst for short sequences (a small number of samples), and at the beginning and end of any finite sequence.
BTW, Nyquist did examine the band-limited frequency content of finite sequences, but did not work on sampling or reconstruction. The sampling theorem is therefore Shannon’s alone. (If other names must be included, they would be Whittaker and Kotelnikov.)
Likes jim mcnamara
Related to Inverse function of the Nyquist-Shannon sampling theorem
1. What is the Nyquist-Shannon sampling theorem?
The Nyquist-Shannon sampling theorem, also known as the Nyquist criterion, is a fundamental concept in signal processing that states that in order to accurately reconstruct a continuous signal from its samples, the sampling frequency must be at least twice the highest frequency component of the signal.
2. Why is the Nyquist-Shannon sampling theorem important?
The Nyquist-Shannon sampling theorem is important because it allows us to accurately represent and reconstruct analog signals in a digital format, which is essential in many modern technologies such as audio and video recording and transmission, digital communication, and medical imaging.
3. What is the relationship between the Nyquist-Shannon sampling theorem and the inverse function?
The inverse function of the Nyquist-Shannon sampling theorem is used to determine the minimum sampling rate required to accurately reconstruct a continuous signal. This inverse function is known as the Nyquist rate and is equal to twice the highest frequency component of the signal.
4. What happens if the sampling rate is lower than the Nyquist rate?
If the sampling rate is lower than the Nyquist rate, the resulting reconstructed signal will contain aliasing, which is the distortion or loss of information in the signal. This can lead to errors and inaccuracies in the signal and can significantly impact the quality of the reconstructed signal.
5. Can the Nyquist-Shannon sampling theorem be applied to all types of signals?
The Nyquist-Shannon sampling theorem is applicable to all types of signals, including audio, video, and digital signals. However, it is important to note that this theorem assumes the signal is bandlimited, meaning that it has a finite frequency range. If the signal is not bandlimited, the sampling rate must be higher than the Nyquist rate to accurately reconstruct the signal.
  • Electrical Engineering
  • Calculus
