Inverse Laplace (stuck @ Partial Fraction)
In summary, Homework Statement is to find the inverse laplace transform of a function. The attempt at a solution was getting to the final step of the partial fraction, but getting lost. The formulas you want are these: cos(at) and sin(at). To complete the square in the one with ##s^2 + 6s + 18##, you need to complete the square in the one with ##s^2 + 6s + 18##.
Italo Campoli
Find the Inverse laplace transform of:
http://www4c.wolframalpha.com/Calculate/MSP/MSP14541hg721e74730d4fb00004644i96f59549h1d?MSPStoreType=image/gif&s=30&w=201.&h=40.
Result http://www4c.wolframalpha.com/Calculate/MSP/MSP14591hg721e74730d4fb000042gcebh89c38eib7?MSPStoreType=image/gif&s=30&w=505.&h=36.
maybe e^(at) forms on the table too since there´s s-a form in a part of the bottom
[/B]
when getting to the final step of the partial fraction i get:
http://www4b.wolframalpha.com/Calculate/MSP/MSP14771df8fbfi46b7gihh000059eh9936e24diiii?MSPStoreType=image/gif&s=24&w=267.&h=22. (sorry about minus, idk what happen to the program ...)
now i could asume that http://www5a.wolframalpha.com/Calculate/MSP/MSP172120i2249gd4beb17900003d9dfc9b6ef7i9e8?MSPStoreType=image/gif&s=54&w=63.&h=20. that being 2i but it gets more complicated than i would expect, see, teacher sayd it is only 1 page long exercise, i would imagine there must be a much simpler way than going by imaginary roots.
I would appreciate if possible a step by step explanation since as a fun fact we were given this exercise without any class about inverse transform and i myself did some research. Thanks in advance
[/B]
You've omitted a lot of work, but it looks like you started with this:
$$\frac{s}{(s^2 + 6s + 18)((s^2 + 4)} = \frac{As + B}{s^2 + 6s + 18} + \frac{Cs + D}{s^2 + 4}$$
If you multiply both sides by ##(s^2 + 6s + 18)((s^2 + 4)##, you get something different from what you show above; namely,
##s = (As + B)(s^2 + 4) + (Cs + D)(s^2 + 6s + 18)##
Note the extra parentheses I show that you don't show. These parentheses make a significant difference.
Expand the right side, and group the terms by powers of s to solve for A, B, C, and D.
Yes, there is. Don't break up the quadratics.
$$\mathcal{L}^{-1}[\frac{s}{s^2 + a^2}] = \cos(at)$$
and
$$\mathcal{L}^{-1}[\frac{1}{s^2 + a^2}] = \sin(at)$$
You'll need to complete the square in the one with ##s^2 + 6s + 18## to make it fit one of these formulas.
Would you mind writing out all of your steps? It would make it easier to check.
and
yes you're quite right that's were i started, i see now, with those parentheses there are less things to group up, ill give it a try thanks for that observation
sorry about that, on mark post above there is the beginning of the exercise, altho ill redo it from his point of view an post any doubt i have later on :P thanks both of you
Related to Inverse Laplace (stuck @ Partial Fraction)
What is the purpose of finding inverse Laplace (stuck @ Partial Fraction)?
The inverse Laplace transform is used to find the original function when given its Laplace transform. The partial fraction decomposition is a method used to simplify the inverse Laplace transform by breaking down the transformed function into smaller, more manageable parts.
How do you perform partial fraction decomposition in inverse Laplace?
To perform partial fraction decomposition in inverse Laplace, the transformed function must first be factored into smaller fractions. Then, the coefficients of each term in the denominator are found by equating coefficients of the original function and the transformed function. Finally, the inverse Laplace transform is taken for each term individually.
What are the common types of partial fraction decomposition used in inverse Laplace?
The two common types of partial fraction decomposition used in inverse Laplace are proper and improper fractions. Proper fractions have a lower degree in the numerator than the denominator, while improper fractions have a higher degree in the numerator.
How do you handle repeated roots in partial fraction decomposition for inverse Laplace?
When a denominator has a repeated root, it results in a repeated term in the partial fraction decomposition. To find the coefficients for these terms, the repeated root is raised to different powers until all the coefficients have been determined.
What are some applications of inverse Laplace (stuck @ Partial Fraction) in science?
Inverse Laplace transform is used in various fields of science, such as engineering, physics, and mathematics. Some applications include the analysis of electrical circuits, control systems, and heat transfer problems. It is also used in image processing and signal analysis.
