docnet
- 437
- Homework Statement
- Find the inverses of the given map F.
- Relevant Equations
- F(x)=y with y = 4x^3-3x
F(u,v) = (x,y) with (x=u^2-v^2, y=2uv)
Any help with this introductory differential geometry HW would be greatly appreciated.
My attempt at solving the first problem:
y=4x^3-3x has the derivative 12x^2-3, which is 0 when x^2=(1/4). {x^2=(1/4)} is the singular set, and the inverse is defined for everywhere except F({x^2<(1/4)}). the image of F inverse does not include the singular set. there are three inverses for -1/2>x>1/2, x<1/2 and x>1/2. All my attempts to find the inverse of F(x) did not give me a solution. The calculator tells me a complicated answer.
Second problem:
the derivative of the map has the determinant 4u^2+4v^2, which is 0 when u=-v. I substituted v=-u into y=2uv, and found u= +/-sqrt(-y/2). then I substituted u back into y=2uv and found v. However, the resulting equation for v and u do not give back y when plugged into y=2uv. It gives back x when plugged into y=u^2-v^2 though. something is wrong. There are four inverses corresponding to the plus/minus signs for u and v. the image of the inverse of F does not contain the singular set {u=-v}. The inverse is not defined for {x=0, y<0} and the the conditions for x and y that makes the solutions for u and v undefined. thank you in advance for any pointers.
Second problem:
