MHB Inverse of adjoint - where is my mistake ?
  • Thread starter Thread starter Yankel
    Inverse Mistake
Yankel
Hello all, I have a matrix A:
\[\begin{pmatrix} 2 &4 &1 \\ -4 &7 &3 \\ 5 &1 &-2 \end{pmatrix}\]
and I need to find the adjoint of the matrix inverse.
I found adj(A) to be:
\[\begin{pmatrix} -17 &9 &5 \\ 7 &-9 &-10 \\ -39 &18 &30 \end{pmatrix}\]
and I found the determinant of A to be -45 and the determinant of adj(A) to be 2025.
Now based on:
\[adj(A^{-1})=(adj(A))^{-1}\]
I tried solving the question, I did:
\[B=adj(A))\]
and looked for:
\[B^{-1}\]
This way:
\[B^{-1}=\frac{1}{\left | B \right |}adj(B)\]
and got:
\[\frac{1}{2025}A\]
which is not the answer. the answer should be:
\[-\frac{1}{45}A\]
And I don't understand what I did wrong here.
Thank you
Now based on:
\[B=adj(A))\]
and looked for:
\[B^{-1}\]
This way:
and got:
\[\frac{1}{2025}A\]
\[-\frac{1}{45}A\]
Thank you
Hi Yankel,
The inverse of $A$ is given by:
$$A^{-1}=\frac{1}{\det A} \text{adj }A$$
See adjugate matrix (as it is called with less ambiguity) on wiki.Speaking about $\det(\text{adj }A)$, it relates to $\det A$ as:
$$\det(\text{adj }A) = (\det A)^{n-1} = (-45)^{3-1} = 2025$$
I like Serena, thank you !
among the formulas out there I mentioned that I did find det(adj(A)) to be 2025, it was easy to miss this line.
This is not what I am asking. Taking the first formula you mentioned, I found the adj(inverse of A), and I was wrong, and can't find my mistake.
We have:
$$A^{-1} = \frac 1{\det A} \text{adj }A$$
Therefore we also have:
$$A = \frac 1{\det A^{-1}} \text{adj}(A^{-1}) \quad\Rightarrow\quad \text{adj}(A^{-1}) = \det A^{-1} \cdot A = \frac 1{\det A} \cdot A$$
Yankel said:
Now based on:
\[B=adj(A))\]
and looked for:
\[B^{-1}\]
This way:
Let's substitute $B=\text{adj}(A)$. That gives us:
\[B^{-1}=\frac{1}{\left | \text{adj}(A) \right |}\text{adj}(\text{adj}(A))\]
Did you evaluate $\text{adj}(\text{adj}(A))$?
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
