Inverse of F: {(1,2)(2,2)(3,2)(4,5)(5,3)}
  • MHB
  • Thread starter JProgrammer
  • Tags
    Inverse
In summary: This is the difference between a definition of a "function" and a definition of a "relation". The "inverse function" of a function is a relation, not a function. In this case, the inverse relation is F^{-1}= {(3, 1), (2, 2), (2, 3), (2, 4), (5, 5)}. In summary, the given F is a function from the set {1, 2, 3, 4, 5} to the set {2, 3, 5}, and its inverse, F^{-1}, is a relation that switches the first and second elements in each ordered pair of F, resulting in F
JProgrammer
F has the following sets:
F = {(1,3)(2,2)(3,2)(4,2)(5,5)}
Does F^-1 mean:
F = {(1,2)(2,2)(3,2)(4,5)(5,3)}
Thank you.
Several remarks.
  1. $F$ is probably a binary relation.
  2. Elements of a set are listed in curly braces and are separated by commas.
  3. Things like $(1,3)$ are not sets, but ordered pairs. There is also a set $\{1,3\}$, but $\{1,3\}=\{3,1\}$ as sets, while $(1,3)\ne(3,1)$ as ordered pairs.
JProgrammer said:
Does F^-1 mean:
The definition of the inverse of a binary relation $F$ is as follows.
F^{-1}=\{(y,x)\mid (x,y)\in F\}
That is, you need to take every ordered pair in $F$ and switch the first and second elements in it.
The given F is a function from the set {1, 2, 3, 4, 5} to the set {2, 3, 5} (which can be interpreted as a subset of {1, 2, 3, 4, 5}). We can think of it as changing 1 to 3 (or "changing 1 to 3" or "mapping 1 to 3"), 2 to 2, 3 to 2, 4 to 2, and 5 to 5. Its inverse, [tex]F^{-1}[/tex], usually read as "F inverse", goes the opposite way, changing 3 to 1, 2 to 2, 2 to 3, 2 to 4, and 5 to 5. It can be written as [tex]F^{-1}= {(3, 1), (2, 2), (2, 3), (2, 4), (5, 5)}[/tex].
That [tex]F^{-1}[/tex] is not a function- it is, rather, the more general "relation" (every function is a relation, not every relation is a function). The difference is that, for a function, which can always be written as "y= f(x)", the same value of x cannot give different values of y: we cannot have 2= f(2) and 3= f(2).
FAQ: Inverse of F: {(1,2)(2,2)(3,2)(4,5)(5,3)}
What is the inverse of the given function?
The inverse of the given function is {(2,1)(2,2)(2,3)(5,4)(3,5)}.
How do you find the inverse of a function?
To find the inverse of a function, switch the x and y values of each ordered pair and solve for y. This will give you the inverse function.
Is the given function one-to-one?
Yes, the given function is one-to-one because each input (x-value) maps to a unique output (y-value).
How do you check if a function has an inverse?
A function has an inverse if it is one-to-one, meaning each input has a unique output. This can be checked by graphing the function and performing the horizontal line test.
Can a function have more than one inverse?
No, a function can only have one inverse. This is because the inverse function must pass the vertical line test, meaning each output (y-value) must correspond to only one input (x-value).
