Enzipino
- 13
Hello,
I've been using Caratheodory's Lemma to prove the Inverse Function Theorem and Fermat's Theorem. I have managed to prove both of them, I would just like someone to look over my proof and tell me if I'm missing anything (i.e. should I clarify any parts of my proof). So here goes:
Inverse Function Theorem - Suppose that $f$ is a one-one continuous function (this means it's bijective right?) on an interval $S$, $f$ is differentiable at a given number ${x}_{0}\in S$, and $f'({x}_{0})\ne0$. Then $f^{-1}$ is differentiable at the number $f({x}_{0}) = {y}_{0}$ and we have $(f^{-1})'({y}_{0})=\frac{1}{f'({x}_{0})}$
For Fermat's Theorem, my book has it in 5 parts but I'm just going to post the 5th part which is the main theorem. I will be using 2 other parts concerning the maximum:
1. If $x$ is not the right endpoint of $S$ and $f'(x)>0$, then $f$ cannot have a max at $x$.
2. If $x$ is not the left endpoint of $S$ and $f'(x)<0$, then $f$ cannot have a max at $x$.
Fermat's Theorem - Suppose that $f$ is a function defined on an interval $S$ and that $f$ is differentiable at a number $x\in S$. If $x$ is not an endpoint of $S$ and $f$ has either a maximum or minimum value at $x$, then we must have $f'(x)=0$.
Any feedback is greatly appreciated. Any tips about how to explain these two things in front of an entire class would be greatly appreciated as well. Thanks!
Proof: Since $f$ is differentiable at $x_0$, $\exists\phi:S\to\Bbb{R}$ such that $\phi(x_0)=w$ and $f(x) = f(x_0) + (x-x_0)\phi(x)$ [Caratheodory's]
Let $x=f^{-1}(y)$, we have $f(f^{-1}(y)) = f(f^{-1}(y_0)) + (f^{-1}(y)-f^{-1}(y_0))\phi(f^{-1}(y))$.
$\implies f(f^{-1}(y))-f(f^{-1}(y_0)) = (f^{-1}(y)-f^{-1}(y_0))\phi(f^{-1}(y))$
$\implies y-y_0=(f^{-1}(y)-f^{-1}(y_0))\phi(f^{-1}(y))$
$\implies \frac{y-y_0}{(f^{-1}(y)-f^{-1}(y_0))}=\phi(f^{-1}(y))$
Flipping both sides of the equation we have $\frac{(f^{-1}(y)-f^{-1}(y_0))}{y-y_0}=\frac{1}{\phi(f^{-1}(y))}$
$\implies (f^{-1})'({y}_{0})=\frac{1}{\phi(x)}$
$\therefore(f^{-1})'({y}_{0})=\frac{1}{f'(x_0)}$
Q.E.D.
Q.E.D.
Proof: Suppose that $f$ has a maximum value at $x$. Using the converse of 1 and 2 above, we have that $f'(x)\le0$ and $f'(x)\ge0$. Thus, $f'(x)=0$.
Q.E.D.
This proof just seems way too easy which has me second guessing myself but I know that the theorem definitely follows from the other parts so by proving those parts, it should lead me to proving this final part.Q.E.D.
