Inverted garbage can and water hydrant
  • Thread starter WannabeNewton
  • Tags
    Water
In summary, the problem involves finding the maximum height at which an inverted garbage can, with weight W, can be suspended in the air by water from a geyser. The water shoots up at a constant rate of \frac{\mathrm{d} m}{\mathrm{d} t} with a velocity of v_{0}. Using the given information, along with the assumption that the water droplets are perfectly rebounded without losing velocity, the maximum height can be calculated using the equation h_{max} = \frac{1}{2g}(v_{0}^{2} - (\frac{W}{2\frac{\mathrm{d} m}{\mathrm{d} t}})^{2}). However, it
WannabeNewton
550
An inverted garbage can of weight W is suspended in air by water from a geyser. The water shoots up at a constant rate [itex]\frac{\mathrm{d} m}{\mathrm{d} t}[/itex] with velocity [itex]v_{0}[/itex]. What is the maximum height at which the garbage can rides? The upwards direction is positive. Answer clue: if [itex]v_{0} = 20\frac{m}{s}, W = 98.1N, \frac{\mathrm{d} m}{\mathrm{d} t} = .5\frac{kg}{s}[/itex] then [itex]h_{max} \approx 17m[/itex].
The net force on the garbage can is [itex]F = F_{I} - W[/itex] where [itex]F_{I}[/itex] is the impact force due to the stream of water. Consider a small amount of the stream of droplets, [itex]\Delta m[/itex] that, at time [itex]t = t_{0}[/itex], is just about to hit the can. We have that [itex]P_{0} = v_{0}\Delta m[/itex] and at [itex]t_{0} + \Delta t[/itex], the time instantly after the rebound\reflection of the small amount of droplets, [itex]P_{f} = -v_{0}\Delta m[/itex] so [itex]\frac{\Delta P}{\Delta t} = \frac{-v_{0}\Delta m - v_{0}\Delta m}{\Delta t} = \frac{-2v_{0}\Delta m}{\Delta t}[/itex]. Therefore, [itex]\lim_{t \rightarrow 0}\frac{\Delta P}{\Delta t} = \frac{\mathrm{d} P}{\mathrm{d} t} = -2v_{0}\frac{\mathrm{d} m}{\mathrm{d} t} = F_{I}[/itex] thus [itex]\frac{W}{g}a = -(W + 2v_{0}\frac{\mathrm{d} m}{\mathrm{d} t})[/itex] so [itex]a = \frac{-(W + 2v_{0}\frac{\mathrm{d} m}{\mathrm{d} t})}{\frac{W}{g}}[/itex]. At the maximum height, the can is instantaneously at rest so [itex]v_{0}^{2} = -2ah_{max}[/itex]. Then, [itex]h_{max} = \frac{Wv_{0}^{2}}{2g(W + 2v_{0}\frac{\mathrm{d} m}{\mathrm{d} t})}[/itex]. Now if I plug in the parameters from the answer clue then I do indeed get [itex]h_{max} \approx 17m[/itex] (16.93480102m to be exact when using g = 9.81m\s^2). My only problem is I had to use a major assumption when arriving at this solution: the water droplets would be rebounded\reflected perfectly so that the velocity of the small amount of droplets instantly after the rebound would be the same as the velocity instantly before hitting the can. If I drop this assumption then I really can't conceive of any way to find the new velocity using only the given information since I won't know how much of the velocity was lost to the can upon impact. If I keep the assumption, I can't exactly convince myself physically why the assumption is true. Any help would be appreciated, thanks!
You are given the velocity of the water, is that the velocity at ground level? If so as the water jet rises it will lose velocity, have you taken that into account? Your assumption that the garbage can "reflects" the water with no lose in velocity is OK I think.
The hydrant pumps out a constant steady jet of water at that velocity for all time so I think we can say the jet of water doesn't lose velocity as it rises.
Any jet of water can only rise so high.
Max height ≈ v^2/2g if shot straight up.
As a water jet rises in our gravitational field it loses kinetic energy.
Maybe others can help?
Yeah I forgot that the droplets do indeed lose velocity as they go up as you stated. I can re-work the problem. Weird that the answer clue worked out for this solution though. Thanks again.
Hey Spinnor, I figured out the solution and there wasn't much to change. I did find out that Kleppner had a mistake in his answer clue for this problem however which is why the answer came out right for the incorrect solution above haha! In the answer clue, dm \ dt should be 6kg\s not .5kg\s which incidentally wouldn't even be enough to raise the garbage can of that weight up that high (17 meters). So anyways I just did [itex]v^{2} = v_{0}^{2} - 2gy[/itex] for the trajectory of the water droplets. Then, [itex]v_{h} = (v_{0}^{2} - 2gh_{max})^{\frac{1}{2}}[/itex] so, keeping the same procedure for finding the impact force as before but using [itex]v_{h}[/itex], [itex]\frac{\mathrm{d} P}{\mathrm{d} t} = 2(v_{0}^{2} - 2gh_{max})^{\frac{1}{2}}\frac{\mathrm{d} m}{\mathrm{d} t} = W[/itex] at the max height so [itex]h_{max} = \frac{1}{2g}(v_{0}^{2} - (\frac{W}{2\frac{\mathrm{d} m}{\mathrm{d} t}})^{2})[/itex].
Related to Inverted garbage can and water hydrant
1. What is an inverted garbage can and water hydrant?
An inverted garbage can and water hydrant is a unique invention that combines a standard garbage can with a water hydrant. The garbage can is placed upside down over the hydrant and serves as a protective cover while also allowing for easy access to the hydrant when needed.
2. How does an inverted garbage can and water hydrant work?
The inverted garbage can and water hydrant works by placing the garbage can over the hydrant and securing it in place. This creates a protective barrier around the hydrant, keeping it safe from damage and debris. When the hydrant needs to be accessed, the garbage can can easily be lifted off and set aside.
3. What are the benefits of using an inverted garbage can and water hydrant?
There are several benefits to using an inverted garbage can and water hydrant. It helps to protect the hydrant from damage and debris, ensuring it is always in working condition. It also prevents unwanted objects from being placed in the hydrant, which can cause blockages. Additionally, it provides easy access to the hydrant when needed.
4. Can an inverted garbage can and water hydrant be used in all weather conditions?
Yes, an inverted garbage can and water hydrant can be used in all weather conditions. The garbage can serves as a protective cover, keeping the hydrant safe from rain, snow, and other elements. This ensures that the hydrant is always ready for use, regardless of the weather.
5. Is an inverted garbage can and water hydrant easy to install?
Yes, an inverted garbage can and water hydrant is easy to install. It simply requires placing the garbage can over the hydrant and securing it in place. This can easily be done by one person and does not require any specialized tools or equipment.
12K
