Investigate how gravity varies over the earth's surface
In summary: Earth."In summary, Newton's model showed that the force of gravity at the equator is weaker than at the poles due to the rotation of the Earth. This is small in absolute terms, but historically it was large enough to be important.
Michaelcarson11
I am doing a school project to investigate how gravity varies over the Earth's surface. I understand that the force is weaker at the equator due to the Earth's rotation but there are a few things that I don't quite understand:
1: Firstly, why is an object on the Earth's surface only affected by the Earth's mass which is within that radius (sorry for the poor explanation but I hope you understand what I mean).
2: If this is the case, then how can you prove that this effect is lesser than the effect of the distance from the centre (because it must be otherwise the gravitational force would be greater at the equator than at the poles)
3: We have also been asked to investigate the effects of mountains, oceans, varying rock densities etc. I can see why they might affect the gravity in a particular region but again, I can't fully understand it
Any help will be greatly appreciated!
Not true.
The force may, in theory, be partially canceled by an opposing force due to inertia from rotation, but that does not make the force of gravity weaker, and it's really a very, very small amount.
In fact, every point on the Earth's surface at sea level is at gravitational equipotential.
I think what you mean is: why do object that are below Earth's surface only affected by the mass within that radius. (i.e. if you are halfway to Earth's core, you only feel gravity from a mass that's half the radius).
The reason for this is that there's a lot of Earth above you pulling up. It can be demonstrated mathematically that the gravitational force within a hollow sphere cancels to zero. So, If you are halfway to the core of Earth, you can divide the Earth into 2 pieces: 1, a ball below you, half Earth's radius, and 2, a hollow shell which you are inside. Now work out the gravitational force you experience.
Uh, you lost me.
Yep, you're on the right track here. Satellites can map the densities of the Earth under the surface (such as, say, the massive Canadian Shield or mountain ranges) by taking careful readings of their altitude changes as they pass over denser areas of the Earth.
google for "geoid"
DaveC426913 said:
Not true.
It may be small in absolute terms, but historically it was large enough to be important.
The first attempts at sea navigation using pendulum clocks as a time reference to find longtitude were seriously affected by the variations of the resultant "gravitation + rotation" force with latitude - all at sea level, of course.
One of Newton's achievements in "Principia" was making a mathematical model of this that was consistent with the experimental facts, and which therefore eliminated other hypotheses that were being proposed - for example that the force of gravity at the equator was weaker because the temperature at the equator was higher than at the poles.
As for the diffierence being "small", Newton's models gave a change in the resultant force, at sea level, from equator to poles as 0.43%. That meant a pendulum clock on a ship might accumulate an error of about 1.5 minutes a day depending what latitude it was at, so the effect wasn't so small it could be ignored!
Ref: "Principia" Book III Proposition XX Problem IV: "To find and compare with each other the weights of bodies in the different regions of our earth".
Not quite, if you are next to a million square km of granite in Canda or the Himalyas in India the difference between astronomical 'UP' as a line from the Earth's centre and gravitational 'UP' from a spirit level can vary by several arc-sec.
The spinning of the Earth would give you less 'weight' on the equator when compared to the poles. This is magnified because this effect has changed the shape of the earth. At the equator you weigh less because of the spin but this spin has pushed the ground out 20km further from the centre than at the poles. Similairly at the poles you weigh more because you are 20km closer to the centre of the Earth.
[strike]i don't believe that is true at all. the Earth is far more spherical than that.[/strike]
(does anyone know the PF markup for strike out?)
what source do you use to come up with the 20 km figure?okay, i looked it up myself and stand corrected. the figures i find are polar diameter: 12,714 km and equatorial diameter: 12,756 km, a difference of 42 km.
mgb_phys said:
Equatorial radius (km) 6378.1
Polar radius (km) 6356.8
From http://nssdc.gsfc.nasa.gov/planetary/factsheet/earthfact.html
I know they faked the moon landings ...
i hope you jest! (but we all have our conspiracy theories. i, personally, cannot believe the "single bullet theory", from a physics and common sense POV.)
... but they should know the shape of the Earth!
Actually I was surprised it was that small, I seem to have a remembered figure of >100km!
i was remembering a deviation from spherical of hundreds of meters for the ocean surface (clearly a faulty memory).
DaveC426913 said:
Not true.
You are mistaking equipotential to mean "equal force". Equipotential means "equal potential energy". Gravitational acceleration is the gradient of the scalar potential field, and this varies over the surface geoid, even though the potential is by definition constant on the surface of the geoid.
Related to Investigate how gravity varies over the earth's surface
1. How does gravity vary over the earth's surface?
Gravity varies over the earth's surface due to factors such as the distribution of mass and topography. Areas with higher concentrations of mass, such as mountains, will have a stronger gravitational pull compared to areas with lower concentrations of mass, such as oceans. Additionally, the shape and density of the earth's surface also influence gravity, with denser materials causing a stronger gravitational pull.
2. What tools are used to investigate gravity variations?
Scientists use a variety of tools to investigate how gravity varies over the earth's surface. One commonly used tool is a gravimeter, which measures the acceleration of gravity at a specific location. Another tool is a satellite, which can measure the gravitational pull of different areas from space. Additionally, scientists also use computer models and simulations to analyze gravity variations.
3. How does gravity affect objects on the earth's surface?
Gravity affects objects on the earth's surface by pulling them towards the center of the earth. This force of gravity is what keeps objects on the surface, preventing them from floating off into space. The strength of gravity also determines an object's weight, with objects in higher gravitational fields having a greater weight compared to objects in lower gravitational fields.
4. Does gravity vary at different latitudes on the earth?
Yes, gravity does vary at different latitudes on the earth. This is due to the earth's shape, which is slightly flattened at the poles and bulging at the equator. The variation in the earth's shape causes a slight difference in the distance from the center of the earth to the surface, resulting in a slight variation in gravity at different latitudes.
5. What are the practical applications of studying gravity variations over the earth's surface?
Studying gravity variations over the earth's surface has many practical applications. For example, it can help us better understand the structure and composition of the earth's interior, monitor changes in sea level and ocean currents, and improve navigation systems. Additionally, this research can also aid in predicting natural disasters such as earthquakes and volcanic eruptions, as well as in the development of new technologies such as satellite communication and space travel.
  • Other Physics Topics
  • Earth Sciences
14K
21K
  • Astronomy and Astrophysics
