Investigating the loss of nitrogen, as urea, from the body
In summary, to investigate the influence of protein consumption on urea excretion in humans, you can use the enzyme urease to catalyze the reaction of urea and water into ammonium carbonate. By measuring the pH change in the reaction mixture using pH indicators and titrating against 0.1 mol dm-3 HCL, you can estimate the concentration of urea in the original solution. The necessary materials for this investigation include 10g per 100cm3 (10%) solution of urea, urease tablets or 5g per 100cm3 (5%) solution of urease, 0.1 mol dm-3 HCL, pH indicators, and school lab resources. It is recommended to use a
SMUDGY
I need to plan an investigation to find out how changes in the consumption of protein in the diet influence the excretion of urea in humans.
it is possible to determine the urea concentration in urine using the enzyme urease which catalyses the following reaction:
Urea+Water --> (with urease on top of arrow) --> Ammonium Carbonate
Ammonium carbonate has an alkaline ph.
Urease breaks down urea, the pH of the reaction mixture changes. Change can be shown by pH indicator. If reaction goes to completion the concentration of ammonium carbonate can be found by titrating against 0.1 mol dm-3 HCL. Volume of HCL used is an estimate of concentration of urea in original solution.
How would i use determine the urea concentration when using urease
This plan needs to be based on materials provided which are:
0.1 mol dm-3 HCL
pH indicators
School lab resources
What apparatus would i use
what is a possible method
Quanticrom and other companies make urea assay kits for urine. Another kind of assay kit is available for BUN - essentially the level of urea in blood. Some of these are expensive but are very accurate. They require that your lab has a colorimeter.
I'm not sure that pH paper or pH indicators is going to be very good at revealing concentrations of ammonium carbonate, but titration will work very well. Ask your lab teacher about titration, if you want to do that.
You do realize that humans may "generate" more or less urine volume (meaning extra water which dilutes urea or less water which increases urea concentration) if they have been sweating profusely, exercising, sleeping, consuming alcohol or caffeine, etc. This means that concetration of urea fluctuates during the day/night.
Simply measuring the concentration in one sample is NOT the same as figuring out how much urea is excreted in a day. Unless you collect and store a full day's production, keeping the reservoir in the fridge, then test one day's worth of urine all at once.
As you stated your problem, I do not think you can get meaningful results. I may have misunderstood.
To determine the urea concentration when using urease, you will need to follow a few steps:
1. Prepare the urease solution: Mix 10g of urea with 100cm3 of water to create a 10% solution of urea. Alternatively, you can use 5g of urea and 100cm3 of water to create a 5% solution. This will be your sample solution for the experiment.
2. Prepare the reaction mixture: Add a few drops of pH indicator to the sample solution to track the change in pH. Then, add the urease tablets (or 5g of urease solution) to the sample solution.
3. Measure the initial pH: Use a pH meter or pH paper to measure the initial pH of the sample solution before adding the urease. Record this value.
4. Monitor the pH change: As the urease breaks down the urea, the pH of the solution will change. Use the pH indicator to track this change and record the final pH when the reaction is complete.
5. Titrate against HCL: Take the final pH of the solution and slowly add 0.1 mol dm-3 HCL to the sample solution until the pH returns to its initial value. The volume of HCL used is an estimate of the concentration of urea in the original solution.
6. Repeat: Repeat the experiment at least three times to ensure accuracy and calculate an average volume of HCL used.
Apparatus needed for this experiment may include:
- Beakers or test tubes
- Pipettes or burettes
- pH meter or pH paper
- Urease tablets or solution
- 0.1 mol dm-3 HCL
- pH indicators
- Water
- Safety goggles and lab coat
Possible method:
Related to Investigating the loss of nitrogen, as urea, from the body
What is nitrogen and how is it lost from the body?
Nitrogen is a chemical element that is essential for many biological processes in the body, such as building proteins and DNA. It is mainly lost from the body in the form of urea, a waste product produced by the breakdown of proteins.
What factors can contribute to the loss of nitrogen as urea from the body?
The amount of urea excreted from the body is influenced by several factors, including diet, physical activity, and kidney function. A diet high in protein can increase the amount of urea produced, while certain health conditions or medications can affect how efficiently the kidneys remove urea from the body.
Why is it important to investigate the loss of nitrogen as urea from the body?
Understanding the mechanisms of nitrogen loss is crucial for maintaining a healthy balance of nitrogen in the body. Excessive nitrogen loss can lead to protein deficiency and other health issues, while insufficient loss can result in a buildup of toxic waste products.
What methods are used to measure the loss of nitrogen as urea from the body?
There are various methods for measuring urea levels in the body, including blood and urine tests. These tests can determine the amount of urea being produced and excreted, providing insight into the overall balance of nitrogen in the body.
How can the loss of nitrogen as urea from the body be prevented or managed?
The most effective way to prevent excessive nitrogen loss is by maintaining a balanced and healthy diet. Consuming enough protein to meet the body's needs, while also monitoring and managing any underlying health conditions, can help prevent disruptions in the nitrogen balance. In some cases, medications or supplements may also be prescribed to help regulate nitrogen levels.
  • Chemistry
10K
