Ionic equation, question about how the answer is derived here?
  • Thread starter land_of_ice
  • Tags
    Ionic
In summary, the ionic equation for the given reaction shows the charged species involved, with the neutral Zn losing 2 electrons on the right side of the equation. Not all elements in the ionic equation necessarily have a charge, as it represents the formal charge of the atoms involved.
land_of_ice
137
2HCL (aq) + Zn (s) ----->H2 (g) + ZnCl2 (aq)
Ionic equation
2H+ (aq) +2CL-(aq) +Zn (s) + Zn2+(aq) + +2CL-(aq)
above is the original equation and the next step is the ionic equation also above, why in the ionic equation don't they put charges on everything ? like the Zn, on the left side of the ionic equation part, the book has no charge on it ? Doesn't everything in the ionic equation get a charge?
one more question about this:
also, how did the Zn get a charge of 2+ on the right side then of the ionic equation?
An ionic equation is a way of writing the equation focusing on the charged species ("ions"). That doesn't mean that everything in the equation has to have a charge.
What's really being written here, is the 'formal' charge of an atom---which is an "effective" charge. On the L.H.S. (left-hand side) the Zn is neutral---thus it has no charge. On the R.H.S. the Zn is no longer neutral---it lost 2 electrons to the hydrogen (which is missing from the R.H.S.). This is therefore a "redox" reactions (in which electrons are exchanged).
FAQ: Ionic equation, question about how the answer is derived here?
1. What is an ionic equation and how is it different from a chemical equation?
An ionic equation is a type of chemical equation that shows the dissociation of ionic compounds into their constituent ions in a solution. It only includes the species that actually participate in the reaction, whereas a chemical equation includes all the reactants and products, even if they do not participate in the reaction.
2. How is an ionic equation written?
An ionic equation is written by separating the ionic compounds into their constituent ions, with the charges written as superscripts. The spectator ions, which do not participate in the reaction, are written on the same side as both reactants and products, and are usually canceled out to simplify the equation.
3. What is the purpose of writing an ionic equation?
The purpose of writing an ionic equation is to clearly show the ions that are involved in a chemical reaction, making it easier to understand the actual chemical changes that are occurring. It also helps to identify the spectator ions and simplify the equation.
4. How do you balance an ionic equation?
An ionic equation is balanced by making sure that the number of each type of ion is the same on both sides of the equation. This can be done by adjusting the coefficients in front of each compound, while also ensuring that the charges are balanced.
5. Can an ionic equation be converted back into a chemical equation?
Yes, an ionic equation can be converted back into a chemical equation by adding the spectator ions back into the equation and removing the charges from the ions. This will result in a balanced chemical equation that shows the overall reaction, including all the reactants and products.
