Ionisation levels in hydrogen and helium
This means that the spatial part of the wavefunction must be symmetric while the spin part must be antisymmetric (singlet) or symmetric (triplet). The splitting occurs because electrons can have parallel or antiparallel spins, which affects their total energy.
jools holland
a) Explain qualitatively why the energy required to remove one electron from the ground state of the helium atom is much larger than that in hydrogen, while for other states the hydrogenic value is quite a good approximation, e.g. the 1s2s levels in helium have energies very similar to the 2s energy in hydrogen.
b) The 1s2s configuration in helium is split into two levels. Explain briefly the physical origin of the splitting, and how it comes about that these different energies should be associated with different relative orientations of the intrinsic spins of the two electrons (so that one of the levels is called a “singlet”, and the other a “triplet”).
none
a) The ground state of helium has direct exposure to a greater charged nucleus than hydrogen so the ionisation energy is greater. The other levels of helium are shielded by previous levels' electrons.
b) no idea.
[/B]
a) I agree with you.
b) "Singlet" and "triplet", these are your keywords. Splitting occurs because there is the total wavefunction must obey Pauli principle, i.e. it must be antisymmetric.
Related to Ionisation levels in hydrogen and helium
1. What is ionisation?
Ionisation is the process of removing one or more electrons from an atom or molecule, resulting in a positively charged ion.
2. What determines the ionisation level in hydrogen and helium?
The ionisation level in hydrogen and helium is determined by the energy required to remove an electron from the atom. This energy is known as the ionisation energy and is different for each element.
3. How does temperature affect the ionisation levels in hydrogen and helium?
As the temperature increases, the atoms of hydrogen and helium gain more energy and their electrons become more loosely bound. This results in a lower ionisation energy and therefore a higher level of ionisation.
4. What is the significance of ionisation levels in hydrogen and helium?
The ionisation levels in hydrogen and helium are important because they determine the properties and behavior of these elements. For example, the ionisation of hydrogen atoms is responsible for the formation of the Sun's energy through nuclear fusion.
5. How are ionisation levels measured and calculated?
The ionisation levels in hydrogen and helium can be measured using spectroscopy, which involves analyzing the light emitted or absorbed by the atoms. The ionisation energy can also be calculated using mathematical equations based on the atomic structure and properties of the elements.
  • Atomic and Condensed Matter
