Ionization & photoelectrons in x-ray solid state detectors
In summary, the principle of solid state x-ray detectors involves a photon of energy E entering the detector and going through photoelectric absorption, resulting in a photoelectron with energy (E - Φ) being ejected. This process creates a number of electron-hole pairs, which are collected to determine the energy of the original x-ray. The amount of electron-hole pairs created is proportional to the energy of the original x-ray, up to a certain point. However, for low energy photons (250-400 eV), the amount of electron-hole pairs may be lower due to the decay of the 100 eV hole and the possibility of photons escaping the detector without being detected.
XRF_Rebel
As far as i understand, this is the principle of solid state x-ray detectors:
1. A photon of energy E enters the detector and goes through photoelectric absorption
2. As a result a photoelectron with energy (E - Φ) is ejected, where Φ is the binding energy required to eject the photoelectron.
3. A number of electron-hole-pairs are created, they are collected and thus the energy of the original x-ray can be determined.
What I'm confused about is, is the amount of electron-hole-pairs proportional to E or actually (E - Φ) ? As far as i understand, the ionization cloud (ie. electron-hole-pairs) is created by the photoelectron, which has an energy of (E - Φ). Textbooks usually cite though, that the amount of electron-hole-pairs is proportional to the original x-ray energy E, but shouldn't that mean that the energy Φ would also have to be converted into electon-hole-pairs? How exactly is the energy Φ "absorbed" in this case? (Assuming that fluorescence or Auger electron emission does not happen).
Many thanks in advance.
Usually, E (i.e. the photon energy for x-rays) is in the keV range. Φ in this case is the work function of the material, and it is in the low eV range. So E-Φ is not statistically different when compared to E in this process.
Just so you know, the "electron-hole" pairs that are created is not the electron-hole pair that was created by the original incoming x-ray photon. In a photoelectric/photoemission process, one photon creates one electron-hole pair (single-photon photoemission). However, in the case of an x-ray detector, that first photoelectron was created deep in the bulk of the material (since x-ray is very penetrating). This photoelectron has a lot of energy still, and so it "rattles around" the semiconductor, knocking off other electrons. Many of these electrons will have energy higher than Φ, and thus, they too create electron-hole pairs. The higher the incoming x-ray, the higher the energy of that first photoelectron, and the more electron-hole pairs are created in the material. This is why you detect a higher current corresponding to higher energy x-ray (up to a point).
Zz.
Thanks for the reply, however I'm still confused.
As far as i understand: in this case of photoelectric absorption, Φ is not the work function but the binding energy, eg. for Si it has values over 100 eV.
I'm especially interested in detection of low energy photons (250-400 eV).
Example:
Photon of 250 eV arrives at Si.
-> Photon ejects a photoelectron from L shell, the binding energy is 100 eV.
-> Photoelectron of just 150 eV is ejected, correct?
For electron-hole-pair generation via ionization (ie by a free electron if I'm correct), the mean energy required to produce one pair in Si is 3,6 eV.
So would the amount of electron-hole-pairs detected now be just 42 on average, instead of 69? (150/3,6 = 42 and 250/3,6 = 69)
The 100eV hole will not just stay there but decay, either emitting Auger electrons or another, softer x-ray photon that is probably re-absorbed in the detector.
It can happen that photons of a characteristic energy "escape" the detector without being detected. This can give rise to a lower energy side peak called "escape peak",
Example:
I checked a few sources, and I reconfirmed what I said earlier (for example, see this http://www.princetoninstruments.com/Uploads/Princeton/Documents/TechNotes/Direct_detection_of%20_xrays_technote_1RevA0.pdf, Pg. 3).
The Φ is the work function IF the photoelectron is to produce subsequent cascade of electron-hole pairs. It is the only range of photoelectron that has enough "leftover energy" to cause a substantial series of multiple scattering to create all these electron-hole pairs.
For the photon that excites the core level electrons (i.e. if it has to overcome a larger binding energy beyond the valence band), then these will not result in a considerable electron-hole pairs. Rather, they will be the ones that will likely result in the Auger or photoluminescence processes.
Zz.
Many thanks for the replis, i think i understand this now better.
Related to Ionization & photoelectrons in x-ray solid state detectors
1. What is ionization in x-ray solid state detectors?
Ionization in x-ray solid state detectors refers to the process of removing electrons from atoms or molecules in a material when it is exposed to x-rays. This creates positively charged ions and free electrons that can be measured to detect the presence and intensity of x-rays.
2. How do x-ray solid state detectors detect photoelectrons?
X-ray solid state detectors use a semiconductor material, typically silicon or germanium, which has a band gap that allows it to absorb x-rays and create photoelectrons. The photoelectrons are then collected and measured to determine the characteristics of the incident x-rays.
3. What is the difference between direct and indirect detection in x-ray solid state detectors?
Direct detection in x-ray solid state detectors refers to the process of directly measuring the photoelectrons created by the absorption of x-rays in the semiconductor material. Indirect detection, on the other hand, involves using a scintillator material to convert x-rays into visible light, which is then detected by the semiconductor material.
4. How does the energy of the incident x-rays affect the ionization and photoelectron production in x-ray solid state detectors?
The energy of the incident x-rays determines the number of electrons that can be ionized in the semiconductor material, which in turn affects the number of photoelectrons that can be produced. Higher energy x-rays can create more ionization and photoelectrons, resulting in a stronger signal in the detector.
5. Can x-ray solid state detectors be used for quantitative analysis?
Yes, x-ray solid state detectors can be used for quantitative analysis by measuring the intensity of the photoelectrons produced by the incident x-rays. This signal can then be compared to known standards to determine the concentration or amount of a specific element or substance in a sample.
  • Atomic and Condensed Matter
  • Quantum Physics
  • Nuclear Engineering
