IR Laser makes glowing spot on radiometer vane
  • I
  • Thread starter Swamp Thing
  • Tags
    Ir Laser
Swamp Thing
Insights Author
989
712
Is the explanation at the end of the video correct?
What's the explanation ? maybe give a timestamp. First things that come to mind are either a) gets hot, glows red, or b) frequency upshift.
Likes Vanadium 50 and russ_watters
@Swamp Thing , it's not like you are new here. "Here's a video, 'splain it to me" is a bad thread start. You've been here long enough to know what you get out of PF is proportional to what you put into PF.
Likes nasu
Sorry, yes the question should have included more detail...
At 03:15 he points the laser at his palm, apparently without feeling the least bit of discomfort. Yet the laser is able to produce a white-hot incandescent spot on the metal.
Moreover, I would have thought that the metal would have a bit of thermal time constant when cooling down, at least enough to produce a short trail as the spot moves around over it (likely going through white, orange and red while cooling).This does not seem to be the case.
Finally, he is saying that convection can pretty much kill the phenomenon but conduction and radiation don't matter enough to prevent it.
These points led me to wonder if a non-thermal explanation should be considered, such as the one he mentions earlier.
Conduction requires cross-section ; those vanes look pretty thin. I'm not sure why "radiation doesn't matter" : where does he think the glow is coming from ?
He says the laser is heating the metal to incandescence. He also says that convection is the reason that it doesn't work in air.
The "radiation doesn't matter" is not something that he actually says, but it follows if we accept the hypothesis that it is a heating effect. If radiation mattered, then it wouldn't have glowed even in vacuum.
If the thinness of the vanes is helping to eliminate conduction cooling, then it should also slow down the cooling process when the laser spot moves away from a given position, and we should then see a cooling trail as the spot moves around. But we don't see a trail.
Unless you've perfect conduction, it's going to glow. Whether that glow extends far enough into the visible spectrum to see is another thing.
If we can ignore conduction and make enough other gross simplifications and assumptions to make a few eyes twitch here and there, we can stick the output power and dot size of the laser pretty much directly into the Stefan Boltzmann law to get the temperature.
$$T=\left( \frac P{A\sigma}\right)^{\frac14}$$
dimensions:
##T## Kelvin
##P## Watts (= Joules per second)
##A## square meters
##\sigma## Stefan-Boltzmann Constant :
##5.670374419...\times10^{−8} W⋅m^{−2}K^{−4}##
Likes Swamp Thing
I think P needs to be the power absorbed and so will be incident power minus reflected power.
Oh, definitely, but that would require knowing the composition of the leaf (which I imagine is carbon-deposited aluminum, but really have no clue).
