Is Mass Variation Relevant in Analyzing Tape Dynamics Down a Ramp?
In summary: First, a note of caution in using that equation.##F=\frac{dp}{dt}##, where F is an external force applied to a system, is only valid if p is the momentum of a closed system. So if you expand it to ##F=m\frac{dv}{dt}+v\frac{dm}{dt}## then ##\frac{dm}{dt}=0## and we recover the familiar F=ma.I found it helpful first to consider a simpler problem: the spool rolling along a horizontal surface. As the radius shrinks, the angular velocity must increase relative to the linear velocity.
A13235378
50
A flexible strip of length L is wound and its free end is fixed by a nail to the surface of an inclined plane that forms an angle θ with the horizontal. Then, the tape is allowed to unwind as it descends the slope.
How long will the tape be completely unrolled?
I = mR^2 /2
Hello everbody,
I found the following resolution:
We can consider the winding of the wire as a thin disc.
Like this,
For a given instant t, we will have M (t) mass of the disc and R (t) radius of the disc.
Analyzing linear dynamics:
$$M(t)gsen\theta - T = M(t).a $$
Analyzing the rotational dynamics:
Resulting torque = moment of inertia. angular acceleration (modularly)
Considering the center of the disk as the point of rotation, the only force that will make torque is traction.
$$T.R(t) = I \alpha = I . \frac{a}{R(t)}$$
The moment of inertia for a thin disc is given by:
$$I=\frac{M(t).R(t)^2}{2}$$
Replacing
$$T=\frac{M (t)R (t)^2.a}{2}$$
Substituting T, we find that the linear acceleration will be:
$$a=\frac{2}{3}.g.sen\theta$$
Realize that this linear acceleration is constant over time.
So, we can apply a cinematic:
$$S=\frac{at^2}{2}$$
Replacing S with L and isolating t:
$$t=\sqrt{\frac{3L}{gsin\theta} }$$
My question is:
Why in the analysis of the translation dynamics did you not consider the contribution of the system's mass variation? Since this is a variable mass system, shouldn't we use that in the tangential direction $$F = \frac{Mdv}{ dr} + \frac{udm}{dt}$$ where $$u$$ is the relative velocity of mass ejection in relation to the analyzed body?
Likes Delta2
It occurs to me that this is not a thin disc. It is just a tiny bit heavier on the down-hill side than on the up-hill side.
Which means that the following is not completely correct.
It further occurs to me that there is an insight that would allow this effect to be addressed cleanly: Consider the trajectory of the center of mass of the remaining spooled tape.
In the present case, the subtlety is that although ##v=r\omega##, it is not true that ##a=r\alpha##.
Likes NTesla
@A13235378 , are you still working on this? Were you able to correct your equation for the relationship between a and α?
Here's how I dealt with the horizontal version:
Tape length = L, thickness h, initial radius r0, initial velocity v0, initial angular velocity ω0.
Lh=πr02
v0=r0ω0
##\frac{dr}{d\theta}=-h##
##\dot r=\frac{dr}{d\theta}\frac{d\theta}{dt}=-h\omega##
##v=r\omega##
Differentiating
##a=\frac d{dt}v= \dot r\omega+r\alpha=-h\omega^2+r\alpha##
If T is the tension in the tape on the ground (or, equivalently, static friction)
##T=-ma=mh\omega^2_mr\alpha##
and for torque:
##Tr=\frac 12mr^2\alpha##
Whence
##h\omega^2=\frac 32r\alpha##
Substituting for α and ω from prior equations
##\frac{\ddot r}{\dot r}=-\frac 23\frac{\dot r}r##
Integrating
##\dot r=Ar^{-\frac 23}##
From initial conditions, ##A=-h\omega_0r_0^{\frac 23}##
Integrating again
##\frac 35r^{\frac 53}=c+At##
##\frac r{r_0}=1-\frac{5h\omega_0t}{3r_0}=1-\frac{5\pi v_0 t}{3L}##
When the tape runs out, r=0, ##t=\frac{3L}{5\pi v_0}##.
Looks persuasive, but that answer is much less than L/v0; I feel sure it should be more than L/v0. So maybe I have an error somewhere.
What does Irodov give as the answer in the slope case?
Likes Lnewqban
I set up the problem almost exactly how you did, but I did something a little different here. I thought about the variable mass equation ##\vec{F}_{\text{ext}} + \vec{v}_{\text{rel}} \frac{dm}{dt} = m\vec{a}##, let the system be the cylinder, and considered that the "exhaust velocity" ##\vec{v}_{\text{rel}}## of the tape just about to leave the system and to come into contact with the table, with respect to the centre of mass of the cylinder, being ##-r\omega \hat{x}##. So in addition to the tension from the tape, you also have this extra term due to mass transfer out of the system [in the derivation of the variable mass equation, the external force acts on both the system and the mass ##-dm## that leaves in a time interval ##dt##]. What do you think?
In any case, it might not make too much of a difference so long as ##\dot{m}/m## is small...
Likes Lnewqban
Should this be ##\large \frac{dr}{d\theta} = -\frac{h}{2\pi}##?
Likes Lnewqban and haruspex
Ah, thank you. I changed my notation while transcribing, not a wise move.
I believe that changes my final expression to ##\frac{6L}{5v_0}##, which is very reasonable.
Likes Lnewqban and TSny
You could be right. It can be hard figuring out when and how to use that variable mass equation.
In the present case, what exactly is Fext, and how does it relate to the torque?
To try to resolve this, consider a small step as occurring in two parts: first, the spool advances and rotates as though there were no friction/tension. So now it is moving a tad too fast for its rotation rate.
Next, a small horizontal impulse dI from the ground brings the two back into synch:
##m.dv=-dI##
(That m has reduced slightly is a second order small quantity there, and again for m and r below.)
##\frac 12mr^2.d\omega=r.dI##
Hence ##r.d\omega=-2.dv##
Before: ##v=r\omega##
After: ##(v+dv)=(r+dr)(\omega+d\omega)=r\omega+\omega.dr+r.d\omega##
Pulling that all together: ##3dv=\omega.dr##. That's the same as I had before.
Likes etotheipi and Lnewqban
Related to Is Mass Variation Relevant in Analyzing Tape Dynamics Down a Ramp?
1. What is the Irodov: Tape going down a ramp problem?
The Irodov: Tape going down a ramp problem is a physics problem that involves a tape being released from the top of a ramp and sliding down to the bottom. It is a classic example of a conservation of energy problem.
2. What are the key concepts involved in solving the Irodov: Tape going down a ramp problem?
The key concepts involved in solving this problem include conservation of energy, potential energy, kinetic energy, and friction. The problem can also be solved using principles of Newton's laws of motion and work-energy theorem.
3. How can I approach solving the Irodov: Tape going down a ramp problem?
To solve this problem, you can start by drawing a free-body diagram of the tape on the ramp and identifying all the forces acting on it. Then, use the conservation of energy equation to find the final velocity of the tape at the bottom of the ramp. Finally, use the work-energy theorem to calculate the distance traveled by the tape.
4. What are some common mistakes made when solving the Irodov: Tape going down a ramp problem?
Some common mistakes made when solving this problem include forgetting to consider the frictional force, using the wrong equation for conservation of energy, and not properly setting up the free-body diagram. It is important to carefully consider all the forces acting on the tape and use the correct equations to solve the problem.
5. How can I improve my understanding of the Irodov: Tape going down a ramp problem?
To improve your understanding of this problem, you can practice solving similar problems and seek help from a physics teacher or tutor if needed. You can also watch online tutorials or read textbooks to gain a deeper understanding of the concepts involved. It is important to approach the problem systematically and review any mistakes made to improve your understanding.
9K
