Exploring Plasma, Iron & Noble Gases: Temperature & Solid State
In summary, plasma is similar to a gas, but with some electrons separated from the nuclei, making it positively charged. There is no clear temperature at which iron becomes a gas, as there is no clear border between gas and plasma. However, at a temperature of around 3000K, the fraction of ionized atoms in iron is low. A noble gas like neon can become a solid at around 24.5K, but only under standard pressure. Helium, on the other hand, requires a minimum of 20 atmospheres and extremely low temperatures to become a solid. The critical pressure of helium is 2.24 atm, and the equilibrium vapor pressure at the solidification temperature is lower than this. There is no direct
CthlhuLies
The way I understand plasma is that is almost a gas except some of the electrons of separated from the nuclei entirely making positively charged. Is there a temperature in which Iron is by definition a gas, and not a plasma?
Also, can something like a noble gas become a solid?
Sure. Neon, for instance turns solid at about 24.5 K.
Would this have to be under pressure or could it be 24.5 kelvin in a vacuum and still be a solid?
Also nice job on the 700 posts :D
That's at standard pressure. Only helium does not turn solid at standard pressure. If memory serves, a minimum of 20 atmospheres is required (and extremely low temperatures) to produce solid helium
The critical pressure of helium is 2.24 atm., so the equilibrium vapor pressure at the solidification temperature is lower than this.
Chet
There is no clear border between gas and plasma - if you increase the temperature, you just increase the fraction of ionized atoms.
The first ionization energy of iron is 8 eV and iron becomes a gas at ~3000K or ~1/4 eV, at this temperature the fraction of ionized atoms is low (but still existent).
Where is the relation between the critical pressure (=gas/liquid related) and the solid phase?
Here is a phase diagram of helium
Yikes. I've never seen a phase diagram like this before. I guess you learn something new every day. Thanks.
Chet
Related to Exploring Plasma, Iron & Noble Gases: Temperature & Solid State
1. What is plasma and how is it different from gas?
Plasma is a state of matter where a gas is heated to such high temperatures that the electrons separate from the atoms, creating a "soup" of positively charged ions and free electrons. This is different from gas because in gas, the atoms are still bound together and not ionized.
2. Why is iron considered a noble gas?
Iron is not considered a noble gas. Noble gases are elements in group 18 of the periodic table, which include helium, neon, argon, krypton, xenon, and radon. They are called noble gases because they are very stable and do not easily react with other elements.
3. How does temperature affect the state of matter?
Temperature is a measure of the average kinetic energy of the particles in a substance. As temperature increases, the particles gain more energy and move faster, causing them to overcome the attractive forces between them. This can cause a substance to change from a solid to a liquid and then to a gas.
4. What is the solid state of matter?
The solid state of matter is a phase where particles are tightly packed together and have a fixed position. The particles vibrate in place, but do not have enough energy to move around freely like in a liquid or gas. Solids have a definite shape and volume.
5. How does plasma differ from the solid state of matter?
Plasma differs from the solid state of matter in several ways. In plasma, the particles are not bound together and can move freely, unlike in solids where particles are tightly packed. Plasma also has a much higher temperature compared to solids, which allows the particles to become ionized. Additionally, plasma does not have a definite shape or volume like solids do.
