Irrational Equation - I end up in a dead end
  • Thread starter Hivoyer
  • Tags
    Irrational
In summary: First, factorise the left-hand-side:2x^2 - 2x - 2 = 12 - 6xNext, simplify the numerator and denominator as much as possible:2x^2 - 2x - 4 = 12 - 6xFinally, combine like terms:2x^2 - 2x = 8Now you can eliminate the -14 from both sides:2x^2 - 2x = 8Which is the same as the original equation.In summary, 2/(2 - x) + 6/(x^2 - x - 2) = 1
Hivoyer
27
This is the equation:
sqrt= square root
^ = to the power of
First thing that comes to mind is to turn it into this:
2x^2 - 2x - 2 + 12 - 6x = (2 - 2)(x^2 -x -2)
Then it gets real ugly:
x^3 - x^2 - 8x + 14 = 0
If only I could somehow get rid of that +14, I would then divide it all by x and get a normal quadric equation...
x(x^2 - x - 8) + 14 = 0
That should be
2x^2 - 2x -4 +12 -6x = (2-x)(x^2-x-2)
But have you tried dividing ##x^2-x-2## by ##2-x## first?
[tex]\frac{2}{2-x}+\frac{6}{x^2-x-2}=1[/tex]
[tex]\frac{2x^2-2x-4+ 12-6x}{(2-x)(x^2-x-2)}=1[/tex]
You made an error in the first step itself. That's why you are stuck. Try correcting it.
[tex]\frac{2x^2-2x-4+ 12-2x}{(2-x)(x^2-x-2)}=1[/tex]
You've made an error yourself :wink:
thanks for the help, I eventually end up with
(2x-4)/(x^2 - x - 2) = 1
which I turn into
x^2 - x + 2 = 0
and turns out that D < 0, so no real roots.
which I turn into
x^2 - x + 2 = 0
That is incorrect. Please show your work.
sqrt= square root
^ = to the power of
Don't expand the LHS. Factorise. Same for the RHS.
After factoring both sides, you can group terms on the LHS.
You'll find that ##(2-x)^2## is common on both sides.
sqrt= square root
^ = to the power of
In the original form of the problem, simplify the left-hand-side as much as possible before doing anything else.
FAQ: Irrational Equation - I end up in a dead end
What is an irrational equation?
An irrational equation is an equation that contains one or more irrational numbers, which cannot be expressed as a ratio of two integers. These numbers are typically expressed as decimals that do not terminate or repeat.
How do you solve an irrational equation?
To solve an irrational equation, you can use algebraic methods such as factoring, completing the square, or using the quadratic formula. It is also important to simplify the equation and isolate the variable on one side before solving.
Why do we encounter dead ends when solving irrational equations?
Dead ends occur when solving irrational equations because some equations do not have a real solution. This means that the equation has no solution or the solution is a complex number, which cannot be represented on a real number line.
What is the difference between rational and irrational equations?
The main difference between rational and irrational equations is that rational equations contain only rational numbers, which can be expressed as a ratio of two integers. Irrational equations, on the other hand, contain irrational numbers that cannot be written as a ratio of two integers.
How are irrational equations used in science?
Irrational equations are used in various scientific fields such as physics, chemistry, and biology to model complex systems and phenomena. They are also used in engineering and technology to design and develop solutions for real-world problems.
