Irreducibility of Polynomials in R/I[x] and R[x]
  • MHB
  • Thread starter Math Amateur
  • Tags
    Polynomials
In summary, Proposition 2 and the fact that $(R/I)[x]$ is a UFD together show that $p(x)$ must have a factorization in $(R/I)[x]$, which contradicts our assumption and proves Proposition 12.
Math Amateur
MHB
3,998
48
I am reading Dummit and Foote on Irreducibility in Polynomial Rings. In particular I am studying Proposition 12 in Section 9.4 Irreducibility Criteria. Proposition 12 reads as follows:
Let $I$ be a proper ideal in the integral domain $R$ and let $p(x)$ be a non-constant monic polynomial in $R[x]$. If the image of $p(x)$ in $(R/I)[x]$ cannot be factored in $(R/I)[x]$ into two polynomials of smaller degree, then $p(x)$ is irreducible in $R[x]$.
The proof in D&F reads as follows:
Proof: Suppose $p(x)$ cannot be factored in $(R/I)[x]$. This means that there are monic non-constant polynomials $a(x)$ and $b(x)$ in $R[x]$ such that $p(x)=a(x) b(x)$. By Proposition 2, reducing the coefficients modulo $I$ gives a factorization in $(R/I)[x]$ with non-constant factors, a contradiction
BUT! Proposition 2 shows that there is an isomorphism between $R[x]/I$ and $(R/I)[x]$.
How does this guarantee a factorization of $p(x)$ in $(R/I)[x]$?
For your information, Proposition 2 in D&F reads as follows:
Proposition 2. Let $I$ be an ideal of the ring $R$ and let $(I)=I[x]$ denote the ideal of $R[x]$ generated by $I$ (the set of polynomials with coefficients in $I$). Then
[TEX] R[x]/(I) \cong (R/I)[x] [/TEX]
In particular, if $I$ is a prime ideal of $R$ then $(I)$ is a prime ideal of $R[x]$.
Peter
Thank you for bringing this up. It is true that Proposition 2 guarantees an isomorphism between $R[x]/I$ and $(R/I)[x]$, but it does not guarantee a factorization of $p(x)$ in $(R/I)[x]$. However, we can use the fact that $(R/I)[x]$ is a unique factorization domain (UFD) to show that $p(x)$ must have a factorization in $(R/I)[x]$.
Since $p(x)$ cannot be factored in $(R/I)[x]$, it must be irreducible in $(R/I)[x]$ (by definition of a UFD). Therefore, $p(x)$ must be a prime element in $(R/I)[x]$. This means that $p(x)$ must generate a prime ideal in $(R/I)[x]$. By Proposition 2, this prime ideal corresponds to an ideal in $R[x]$ that is generated by $p(x)$ and elements of $I$. In other words, $p(x)$ must generate a prime ideal in $R[x]$.
Now, since $p(x)$ is monic and $R$ is an integral domain, we know that $p(x)$ is irreducible in $R[x]$. Therefore, $p(x)$ must be a prime element in $R[x]$. This means that $p(x)$ generates a prime ideal in $R[x]$. By Proposition 2, this prime ideal corresponds to an ideal in $(R/I)[x]$ that is generated by $p(x)$ and elements of $I$. In other words, $p(x)$ must generate a prime ideal in $(R/I)[x]$.
But since $p(x)$ generates a prime ideal in both $R[x]$ and $(R/I)[x]$, it must also generate a prime ideal in their intersection, which is $(R/I)[x]$. This means that $p(x)$ must have a factorization in $(R/I)[x]$, which contradicts our assumption that $p(x)$ cannot be factored in $(R/I)[x]$.
I hope this explanation helps clarify how Proposition 2, along with the fact that $(R/I)[x]$ is a UFD, guarantees a factorization of $p(x)$ in $(R/I)[x]$.
FAQ: Irreducibility of Polynomials in R/I[x] and R[x]
What is the definition of irreducibility of polynomials in R/I[x] and R[x]?
Irreducibility of polynomials in R/I[x] and R[x] means that a polynomial cannot be factored into non-constant polynomials in the same ring.
How do we determine if a polynomial is irreducible in R/I[x] and R[x]?
To determine if a polynomial is irreducible in R/I[x] and R[x], we can use various techniques such as the Eisenstein criterion, the rational root theorem, and the Euclidean algorithm.
What is the significance of irreducible polynomials in R/I[x] and R[x]?
Irreducible polynomials in R/I[x] and R[x] have a special role in algebraic structures, as they are the building blocks for constructing other polynomials and understanding their properties.
Can a polynomial be irreducible in R/I[x] but reducible in R[x]?
Yes, it is possible for a polynomial to be irreducible in R/I[x] but reducible in R[x]. This is because the quotient ring R/I[x] has different properties and structure compared to the original ring R[x].
Are there any practical applications of studying the irreducibility of polynomials in R/I[x] and R[x]?
Yes, the concept of irreducibility of polynomials in R/I[x] and R[x] has various applications in fields such as cryptography, coding theory, and algebraic geometry. It also helps in solving equations and understanding the behavior of polynomials in different rings.
