Irreducible polynomials over different fields
In summary: Since $\deg (f-k) <\deg f=\deg k$, $f-k$ has $u$ as a root, and by the induction hypothesis, $f-k$ and $k$ have the same coefficients. Thus, $f=k$ over $L$. In summary, we have proven that if $f$ and $k$ are monic irreducible polynomials of the same degree over fields $F$ and $K$, respectively, and they have a common root $u$, then $f=k$ over the field $F\cap K$, i.e. $f$ and $k$ are
ivos
Problem: Let f be monic irreducible polynomial over a field F, k be monic irreducible polynomial over a field K, deg f = deg k. Let u be common root of f and k. Prove (or disprove by counterexample), that f=k over field (F intersection K), i.e. polynomials f and k are identical.
Proof would be easy, if polynomial f would be irreducible over some field which includes fields F and K (with using "Abel's lemma", i.e. for any element u which is algebraic over some field, there is exactly one monic irreducible polynomial f over this field, f(u)=0).
Unfortunately, polynomial f could be reducible over smallest field which includes F and K.
(x^2-6 is irreducible over Q(sqrt(2)) and Q(sqrt(3)) but reducible over Q(sqrt(2), sqrt(3)).
On the other side, if polynomial f-k would be nontrivial, deg (f-k) < deg f=deg k, f-k has u as root. But, we cannot use Abels lemma again, because of polynomial f-k is over larger field than F and K a so can be reducible over this field. It doesn't follow f=k.
How make the right proof (or find counterexample - but I think, that claim is true, i.e. f=k)?
A:Let $F$ and $K$ be two fields, and let $L=F\cap K$. Suppose that $f$ and $k$ are both monic irreducible polynomials of the same degree over $F$ and $K$, respectively. Suppose further that $u$ is a common root of $f$ and $k$. Then we have $f(u)=k(u)=0$.We shall show that $f$ and $k$ are identical as polynomials over $L$. Since $f$ and $k$ are monic, it suffices to show that they have the same coefficients. We proceed by induction on the degree of $f$ and $k$. Suppose first that $\deg f=\deg k=1$. Then $f=X-a$ and $k=X-b$ for some $a,b\in F$ and $K$, respectively. Since $u$ is a common root of $f$ and $k$, we have $f(u)=0=k(u)$, which implies that $a=b$. Thus, $f=k$ over $L$. Now suppose that $\deg f=\deg k >1$, and that the assertion holds for all polynomials of degree less than $\deg f=\deg k$. Let $f=X^n+c_{n-1}X^{n-1}+\cdots + c_1X+c_0$ and $k=X^n+d_{n-1}X^{n-1}+\cdots + d_1X+d_0$ be the respective monic forms of $f$ and $k$ over $F$ and $K$. Since $f$ and $k$ have a common root $u$, we have$$f(u)=X^n(u)+c_{n-1}X^{n-1}(u)+\cdots + c_1X(u)+c_0=0=X^n(u)+d_{n-1}X^{n-1}(u)+\cdots + d_1X(u)+d_0=k(u).$$Comparing coefficients, we find that $c
FAQ: Irreducible polynomials over different fields
What is an irreducible polynomial?
An irreducible polynomial is a polynomial that cannot be factored into smaller polynomials with coefficients in the same field. In other words, it cannot be broken down into simpler components.
How do you determine if a polynomial is irreducible over a specific field?
To determine if a polynomial is irreducible over a specific field, we can use the Eisenstein's criterion or the GCD test. Both methods involve checking if the polynomial satisfies certain conditions that indicate it cannot be factored further.
Can a polynomial be irreducible over one field but reducible over another?
Yes, a polynomial can be irreducible over one field but reducible over another. This is because different fields have different sets of numbers and operations, which can affect the factorization of the polynomial.
What is the significance of irreducible polynomials in mathematics?
Irreducible polynomials play a crucial role in many areas of mathematics, including number theory, algebraic geometry, and coding theory. They are used to construct field extensions, which are essential in many mathematical structures and applications.
Can irreducible polynomials have complex coefficients?
Yes, irreducible polynomials can have complex coefficients. In fact, many fundamental theorems in algebraic number theory involve complex coefficients, such as the fundamental theorem of algebra and the Gauss's lemma.
