Irreducible representations of SL(2,C)?
In summary, the group SL(2,C) can be defined as the set of 2 x 2 complex matrices with a determinant of 1, or as the group of linear transformations that preserve oriented areas in 2-D complex space. It can also be defined as a subgroup of GL(2,C) by requiring the endomorphisms of C2 to have a matrix determinant of 1 in the standard basis. Other representations of SL(2,C) exist, and its formal definition can be found in various sources, such as the groupprops website.
pellman
684
The group of SL(2,C) is sometimes defined (by physicists) as the group of 2 X 2 complex matrices of determinant = 1. But then we can talk about other representations of SL(2,C). So apparently the set of 2 X 2 complex matrices of determinant = 1 is but one representation of SL(2,C). If so, what then is the more formal definition of SL(2,C) ? And what does another irreducible representation or SL(2,C) look like?
Hey pellman.
I think if you had doubts then you should check the appendix of the document or look for documents that confirm what the definition is across documents and departments.
Usually special groups have unit determinants.
Likes pellman
If we believe the groupprops website, SL(2,C) is defined as the set of matrices that has been mentioned. http://groupprops.subwiki.org/wiki/Special_linear_group:SL(2,C) According to the Wikipedia, you could also defined it as the group of linear transformations on 2-D complex space that preserves oriented areas.
Likes pellman
You can define it as the subgroup of GL(2,C) by requiring that the endomorphisms of C2 have a matrix of determinant = 1 in the standard basis of C2.
Likes pellman
thanks, guys
Related to Irreducible representations of SL(2,C)?
1. What is SL(2,C) and why is it important in representation theory?
SL(2,C) is the special linear group of 2x2 complex matrices with determinant 1. It is important in representation theory because it is the simplest example of a non-abelian Lie group, and its representations can be used to understand representations of more complicated Lie groups.
2. What are irreducible representations?
An irreducible representation of a group is a linear representation that cannot be decomposed into smaller, invariant subspaces. In other words, it is a representation that does not have any non-trivial subrepresentations.
3. How do you determine the irreducible representations of SL(2,C)?
The irreducible representations of SL(2,C) can be determined using the theory of highest weight representations. This involves finding a set of generators for the Lie algebra of SL(2,C) and then constructing representations from these generators.
4. What is the relationship between SL(2,C) and the special orthogonal group SO(3)?
There is a close relationship between SL(2,C) and SO(3), as SL(2,C) is the universal cover of SO(3). This means that every irreducible representation of SO(3) can be lifted to an irreducible representation of SL(2,C), but not vice versa.
5. How are irreducible representations of SL(2,C) used in physics?
Irreducible representations of SL(2,C) are used in physics to study the symmetries of physical systems, particularly in quantum mechanics and particle physics. For example, the spin of a particle can be described using an irreducible representation of SL(2,C).
  • Linear and Abstract Algebra
  • Topology and Analysis
