Irritating heap corruption error in VC++2005
  • C/C++
  • Thread starter qxcdz
  • Tags
    Error
In summary, an irritating heap corruption error in VC++2005 is a type of runtime error that occurs due to problems with memory allocation. It can be caused by various factors, such as programming errors or conflicts with other software. Fixing this error can be challenging and time-consuming, but steps can be taken to reduce its likelihood. It is not specific to VC++2005 and can occur in other programming languages and environments as well.
qxcdz
'kay, I've been doing coasting along in C++, overloading operators, defining matrix arithmetic... Except, there's this error stopping my otherwise flawless addition function from working. When the function ends, it calls ~matrix(), probably for the temp variable inside the function, and the delete [] data_ corrupts the heap. How, I don't know, so I'm showing you guys in the hope that someone will spot what I've done wrong.
HelloWorld.cpp:
Code:
#include "stdafx.h"
#include <iostream>
#include <string>
#include "matrix.h"
using namespace std;
typedef unsigned char byte;
int main(int argc, _TCHAR* argv[])
	matrix tst1(5,5);
	matrix tst2(5,5);
	matrix tst3(3,6);
	tst1(3,4)=56;
	tst3=tst2+tst1;
	int tst=tst3(3,4);
	cout << tst;
	return 0;
stdafx.h:
Code:
// stdafx.h : include file for standard system include files,
// or project specific include files that are used frequently, but
// are changed infrequently
#pragma once
#define WIN32_LEAN_AND_MEAN		// Exclude rarely-used stuff from Windows headers
#include <stdio.h>
#include <tchar.h>
// TODO: reference additional headers your program requires here
matrix.h:
Code:
#define MATRIX_TYPE unsigned char
//typedef unsigned char byte; --no longer needed due to #define directive
class matrix
	MATRIX_TYPE* data_; //using underscores to distinguish internal variables -- worth changing the rest of the code?
	int rows_,cols_;
public:
	matrix(int rows, int cols); //constructor
	~matrix(); //destructor DUMMY
	MATRIX_TYPE& operator() (int row, int col); //subscript operator
	MATRIX_TYPE  operator() (int row, int col) const; // subscript operator for constants
	matrix operator+(matrix op1); //matrix addition
	matrix& operator=(const matrix& op1); //assignment of a matrix, to account for size differences
matrix::matrix(int rowin, int colin)
	if(rowin==0){rows_=1;}else{rows_=rowin;};
	if(colin==0){cols_=1;}else{cols_=rowin;};
	data_=new MATRIX_TYPE[(rows_*cols_)-1];
matrix::~matrix()
	delete[] data_;
MATRIX_TYPE& matrix::operator() (int row, int col)
	if(row<rows_ && col<cols_)
		return data_[(cols_*row)+col];
	}else{
		cout << "index out of range for this array" << endl;
		return data_[0];
MATRIX_TYPE  matrix::operator() (int row, int col) const
	}else{
		return data_[0];
matrix& matrix::operator=(const matrix& op1)
	if(this != &op1) //must not be the same object!
		delete[] data_; //get rid of the old data
		rows_=op1.rows_; // make this new matrix have the same dimensions as the old one
		cols_=op1.cols_;
		data_=new MATRIX_TYPE[(rows_*cols_)-1]; //reassign space for data
		for(int r=0;r<rows_;r++)
			for(int c=0;c<cols_;c++)
				data_[(cols_*r)+c]=op1(r,c); //copy data over from other matrix
	return *this;
matrix matrix::operator +(matrix op1)
	if((op1.rows_==rows_)&&(op1.cols_==cols_))
		matrix result(rows_,cols_);
				result(r,c)=op1(r,c)+data_[(cols_*r)+c]; // fill result matrix with sums
		return result; // this line keeps causing a heap corruption!
	}else{
		cout << "matricies are not of equal dimension" << endl;
		matrix ret(1,1);
		return ret;
Technology news on Phys.org
The OP hasn't been around in years, but others might benefit from my analysis of this code.
The most obvious problem is one statement in main():
C:
    matrix tst1(5,5);
    matrix tst2(5,5);
    matrix tst3(3,6);
    tst1(3,4)=56;
    tst3=tst2+tst1;    // <---- Problem here
    int tst=tst3(3,4);
    cout << tst;
    return 0;
In the line with the comment you are 1) adding two arrays of the same size (that's fine), but 2) attempting to store the contents of a 5 x 5 matrix in a 3 x 6 matrix. This won't work.
There is also a problem in the line that follows, where you are attempting to read the value in tst3(3, 4), but the tst3 array has only 3 rows that have indexes of 0, 1, and 2.
The less obvious, but more difficult problems are in your constructor and in your addition operator code.
First, the constructor:
C:
    if (rowin == 0) { rows_ = 1; }
    else { rows_ = rowin; };
    if (colin == 0) { cols_ = 1; }
    else { cols_ = rowin; };
    data_ = new MATRIX_TYPE[(rows_*cols_) - 1];  // <=== Problem here
In the commented line, your heap matrix, data_, is too small. Inside the brackets should be rows_ * cols_. The same problem is present in your assignment operator code.
In your addition operator:
C:
    if ((op1.rows_ == rows_) && (op1.cols_ == cols_))
        matrix result(rows_, cols_);              // <=== Problem here
        for (int r = 0; r < rows_; r++)
            for (int c = 0; c < cols_; c++)
                result(r, c) = op1(r, c) + data_[(cols_*r) + c]; // fill result matrix with sums
    else {
        matrix ret(1, 1);
        return ret;
Your result variable is an automatic variable (allocated on the stack) that goes out of scope as soon as this function returns. When result goes out of scope, the matrix destructor is called before the contents of the array sum can be copied over to the tst3 array in main(). One fix for this is to declare result to be static.
BTW, by making the changes I described, I was able to get the code to work.
Related to Irritating heap corruption error in VC++2005
1. What is an "Irritating heap corruption error" in VC++2005?
An irritating heap corruption error in VC++2005 is a type of runtime error that occurs when there is a problem with the memory allocation process in a program. It can cause the program to crash or behave unexpectedly, making it difficult to identify and fix.
2. What causes an irritating heap corruption error in VC++2005?
An irritating heap corruption error can be caused by a variety of factors, such as a programming error, a hardware issue, or a conflict with other software. Common causes include writing to an uninitialized pointer, freeing memory that has already been freed, or accessing memory beyond its allocated size.
3. How can I fix an irritating heap corruption error in VC++2005?
Fixing an irritating heap corruption error can be a challenging and time-consuming process. The first step is to identify the source of the error, which can be done by debugging the program or using tools such as Visual Studio's Memory Debugger. Once the source of the error is identified, it can be fixed by correcting any programming errors or addressing any hardware or software conflicts.
4. Can an irritating heap corruption error be prevented in VC++2005?
While it is not always possible to prevent an irritating heap corruption error, there are some steps that can be taken to reduce the likelihood of it occurring. These include writing code that follows best practices for memory management, using debugging tools, and performing regular checks for memory leaks.
5. Is an irritating heap corruption error specific to VC++2005?
No, an irritating heap corruption error can occur in other programming languages and versions of Visual C++, as well as other compilers and programming environments. It is a common issue in programming and can be caused by similar factors in different environments.
9K
