Irrotationality somewhere = irrotationality everywhere?
  • Thread starter Ichimaru
In summary, the flow past a cylinder is irrotational because vorticity is zero in an inviscid flow of constant density. This is due to Kelvin's circulation theorem, which states that circulation remains zero as long as the flow remains irrotational. Therefore, even near the cylinder, where circulation may be present, the flow remains irrotational.
Ichimaru
I'm learning about 2D inviscid irrotational flows of constant density. In the example of flow past a cylinder there is the sentence "since the flow is irrotational as r tends to infinity, it is irrotational everywhere" and I can't get my hear around that.
Why is this the case?
Irrotational means that vorticity is zero, and in the case of an inviscid flow of constant density Kelvin's circulation theorem means that it remains zero as you follow any loop of fluid that initially has zero circulation. However I don't see why it is guaranteed that the flow is irrotational near the cylinder if it is irrotational at infinity.
Thanks for any help!
Basically, because flow is inviscid, vorticity is zero within the flow. But you can still have circulation. Imagine that the cylinder rotates. In that case, the flow around it will have circulation. However, because vorticity is zero in the fluid, that circulation is exactly the same around any closed contour containing cylinder in its interior. That's how you get Magnus Effect.
What they are telling you in the text is that for your problem, circulation being zero at infinity implies circulation is zero everywhere throughout the fluid. Therefore, fluid is irrotational.
Consider Helmholtz's theorem as it relates to this situation. You can derive it by taking the curl of the Euler equation and it will show that for a fluid element moving with the flow, tyke vorticity is constant as it convects with the flow for an ideal fluid under the action of conservative body forces.
So, knowing that, if the flow is irrotational far upstream of your cylinder (and that would be true of a uniform free stream), any fluid that starts upstream (and therefore all fluid) will remain at zero vorticity, even under the influence of said cylinder.
Related to Irrotationality somewhere = irrotationality everywhere?
What is irrotationality?
Irrotationality is a concept in fluid mechanics that describes a flow field where the velocity of the fluid at any point is independent of the rotation of the fluid at that point.
What does "irrotationality somewhere = irrotationality everywhere" mean?
This statement means that if a flow field is irrotational at one point, it is also irrotational at all other points in the same flow field.
Why is irrotationality important in fluid mechanics?
Irrotationality is important because it simplifies the mathematical analysis of fluid flow and allows for more accurate predictions of fluid behavior.
Is it always true that irrotationality somewhere = irrotationality everywhere?
No, this statement is only true for ideal fluids in certain conditions. In real-world situations, there may be factors such as viscosity or turbulence that can cause a flow field to be non-irrotational.
How can we determine if a flow field is irrotational?
A flow field can be mathematically analyzed to determine if it meets the criteria for irrotationality, such as satisfying the Laplace's equation or possessing a potential function. Experimental methods, such as using flow visualization techniques, can also be used to observe and confirm irrotationality in a flow field.
  • Classical Physics
  • Mechanics
