Is $\{0,1\}^{\Bbb N}$ homeomorphic to the Cantor Set?
  • MHB
  • Thread starter Chris L T521
In summary, the Cantor Set is a fractal structure created by removing the middle third of a line segment repeatedly. It is related to the set $\{0,1\}^{\Bbb N}$, which is the set of all infinite sequences of 0s and 1s. Two sets are homeomorphic if there exists a continuous and bijective function between them. The function f(x) = 0.x is a way to prove that $\{0,1\}^{\Bbb N}$ and the Cantor Set are homeomorphic. This homeomorphism has applications in fields such as computer science, topology, and dynamical systems.
Chris L T521
MHB
915
This will be my last Graduate POTW submission here on MHB; I'm running out of ideas (after doing this for 124 weeks), and I think it's time to get someone fresh in here to do things from now on. It's been a pleasure doing this for roughly 2.5 years now, and I hope you guys give the person who will be taking my place the same kind of support I've received from you during my time running the Graduate POTW.
Anyway, here's this week's problem!
Problem
: Let $X$ denote the discrete topological space with two elements. Show that $X^{\mathbb{N}}$ is homeomorphic to the Cantor Set.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
This week's problem was correctly answered by Euge. You can find his solution below.
[sp]It suffices to show that $\{0,1\}^{\Bbb N}$ is homeomorphic to the Cantor set, $C$. Define a map $f : \{0,1\}^{\Bbb N} \to C$ by setting
\(\displaystyle f((a_n)) = \sum_{n = 1}^\infty \frac{2a_n}{3^n}.\)
It has an inverse map $g : C \to \{0,1\}^{\Bbb N}$ given by
\(\displaystyle g\left(\sum_{n = 1}^\infty \frac{a_n}{3^n}\right) = \left(\frac{a_n}{2}\right).\)
Thus $f$ is bijective. Furthermore, $f$ is continuous. For consider the metric $d$ on $\{0,1\}^{\Bbb N}$ given by
\(\displaystyle d((a_n), (b_n)) = \sum_{n = 1}^\infty \frac{|a_n - b_n|}{2^n}.\)
Given $\varepsilon > 0$, set $\delta = \frac{\varepsilon}{2}$. For all $(a_n), (b_n)\in \{0,1\}^{\Bbb N}$, $d((a_n), (b_n)) < \delta$ implies
\(\displaystyle |f(a_n) - f(b_n)| \le 2\sum_{n = 1}^\infty \frac{|a_n - b_n|}{3^n} \le 2\, d((a_n), (b_n)) < \varepsilon.\)
Since $\varepsilon$ was arbitrary, continuity of $f$ follows. As $\{0,1\}^{\Bbb N}$ is compact (by Tychonoff's theorem), $f$ is a bijective continuous map of a compact space onto the Hausdorff space $C$, so $f$ is a homeomorphism.[/sp]
FAQ: Is $\{0,1\}^{\Bbb N}$ homeomorphic to the Cantor Set?
What is the Cantor Set?
The Cantor Set is a fractal structure that is created by removing the middle third of a line segment, and then removing the middle third of each resulting line segment, and repeating this process infinitely.
How is $\{0,1\}^{\Bbb N}$ related to the Cantor Set?
The set $\{0,1\}^{\Bbb N}$ is the set of all infinite sequences of 0s and 1s, which can be seen as the binary representation of numbers between 0 and 1. This set is homeomorphic to the Cantor Set, meaning that there is a continuous and bijective function between the two sets.
What does it mean for two sets to be homeomorphic?
Two sets are homeomorphic if there exists a continuous and bijective function between them. This means that the two sets have the same topological properties and can be transformed into each other without any breaks or tears.
How can we prove that $\{0,1\}^{\Bbb N}$ and the Cantor Set are homeomorphic?
One way to prove this is by showing that the function f(x) = 0.x, where x is a binary sequence in $\{0,1\}^{\Bbb N}$, is a continuous and bijective function between the two sets. This function maps each binary sequence to its corresponding number in the Cantor Set, and vice versa.
What are some applications of this homeomorphism between $\{0,1\}^{\Bbb N}$ and the Cantor Set?
This homeomorphism has applications in various fields such as computer science, topology, and dynamical systems. In computer science, it is used for data compression and encryption. In topology, it helps in understanding the structure of the Cantor Set and its properties. In dynamical systems, it is used to study the behavior of chaotic systems.
