MHB Is $10^a\lt 127$ True for the Real Root of $x^3-3x-3=0$?
  • Thread starter Thread starter anemone
    Cubic Root
The discussion revolves around proving that for the real root \( a \) of the equation \( x^3 - 3x - 3 = 0 \), the inequality \( 10^a < 127 \) holds true. The original poster acknowledges a mistake in their initial solution attempt and expresses frustration over not being able to solve the problem as intended. They plan to continue working on the problem and consider alternative methods suggested by other participants. The conversation highlights the collaborative nature of problem-solving in mathematics. Ultimately, the focus remains on finding a valid proof for the inequality involving the real root \( a \).
anemone
MHB
POTW Director
Given $a$ is the real root for $x^3-3x-3=0$, prove that $10^a\lt 127$.
Mathematics news on Phys.org
my solution:
let $f(x)=x^3-3x-3$
$f(2.10351)<0,f(2.10381)>0$
there is a real solution "a" satisfying $2.10351<a<2.10381$
but $log 127\approx 2.10381$
$\therefore 10^a<127$
$$a=2\cosh\left(\dfrac13\cosh^{-1}\left(\dfrac32\right)\right)=\left(\dfrac{3+\sqrt5}{2}\right)^{1/3}+\left(\dfrac{3-\sqrt5}{2}\right)^{1/3}<\log(127)$$
...but I don't have proof. :(
I made a silly blunder...I thought I solved this problem elegantly and so I posted this problem as a challenge...and now that the time has come for me to post my solution, I realize my solution doesn't work. (Angry):o
I have to admit this and I will continue to work on this problem and hopefully, I can crack using a different method than Albert's (thanks Albert for participating) and perhaps work on the idea provided by greg1313.
My solution:
It will suffice to show that:
$$a<\log(127)$$
If we define:
$$f(x)=x^3-3x-3$$
A quick sign check shows us:
$$f(2)=2^3-3(2)-3=-1$$
$$f(3)=3^3-3(3)-3=15$$
So, we know $2<a<3$...and since $10^2<127<10^3$, we also know $2<\log(127)<3$. And so, we may begin the continued fraction representation of each by stating:
$$a\approx[2;\cdots]$$
$$\log(127)\approx[2;\cdots]$$
For the purpose of continuing the computation of the continued fraction representation of $\log(127)$, we will use:
$$\log(127)=2+\log(1.27)$$
To get the next partial quotient for $a$, we will make the substitution:
$$x=\frac{1}{x_1}+2$$
and we then find:
$$f_1\left(x_1\right)=x_1^3f\left(\frac{1}{x_1}+2\right)=x_1^3\left(\left(\frac{2x_1+1}{x_1}\right)^3-3\left(\frac{2x_1+1}{x_1}\right)-3\right)=-x_1^3+9x_1^2+6x_1+1$$
We then observe:
$$f_1(9)=55$$
$$f_1(10)=-39$$
And so we have:
$$a\approx[2;9,\cdots]$$
And using the iterative method outlined >>here<<, we confirm that:
$$1.27^9<10<1.27^{10}$$
Hence:
$$\log(127)\approx[2;9,\cdots]$$
So, we find the next partial quotient for $a$:
$$f_2\left(x_2\right)=x_2^3f_1\left(\frac{9x_2+1}{x_2}\right)=x_2^3\left(-\left(\frac{9x_2+1}{x_2}\right)^3+9\left(\frac{9x_2+1}{x_2}\right)^2+6\left(\frac{9x_2+1}{x_2}\right)+1\right)=55x_2^3-75x_2^2-18x_2-1$$
We find:
$$f_2(1)=-39$$
$$f_2(2)=103$$
Thus:
$$a\approx[2;9,1,\cdots]$$
And we then confirm:
$$\left(\frac{10}{1.27^9}\right)^1<1.27<\left(\frac{10}{1.27^9}\right)^2$$
Hence:
$$\log(127)\approx[2;9,1,\cdots]$$
Continuing this process, we eventually find:
$$a\approx[2;9,1,1,1,2,1,\cdots]$$
$$\log(127)\approx[2;9,1,1,1,2,4,\cdots]$$
And so we may now conclude:
$$a<\log(127)$$
Awesome, MarkFL!(Yes):cool:
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
