Is a clock on the equator time dilated?
In summary, clocks in orbit are time dilated due to their orbital velocity. The greater effect for clocks in orbiting satelites is the increased speed of the clocks due to the increased altitude and decreased gravitational pull. So the orbiting clocks in GPS satelites actually go faster than on Earth.
Grimble
485
Clocks in orbit are time dilated due to their orbital velocity.
Do we measure a similar effect for clocks on the equator when measured against clocks at the poles?
I am sure that they would be. I'm not sure that anyone has ever proved it because the separation distance might be a problem. Also that larger diameter around the equator complicates things. The greater effect for clocks in orbiting satelites is the increased speed of the clocks due to the increased altitude and decreased gravitational pull. So the orbiting clocks in GPS satelites actually go faster than on Earth.
There are two competing effects here. There is the velocity that you already noticed and there is also the equatorial bulge. The velocity causes the equator clock to slow down, but the equatorial bulge causes the equator clock to speed up due to being higher in a gravitational field.
It turns out that for any pair of clocks on the geoid these two effects exactly cancel. So a clock on the geoid at the pole will run at the same rate as a clock on the geoid at the equator.
Likes PeterDonis, David Lewis, russ_watters and 3 others
They exactly cancel? What's the argument for that?
Approximately, the time dilation at different locations is given by ##\Delta \tau \approx \frac{1}{c^2} (\Delta V - \Delta T)##, where ##\Delta V## is the change in gravitational potential (per unit mass) and ##\Delta T## is the change in kinetic energy (per unit mass). For the time dilation to be zero between a clock at the North Pole and a clock at the equator, it must be that ##\Delta V = \Delta T##.
##\Delta T = \frac{1}{2} v^2 = \frac{1}{2} (\frac{2 \pi R}{T})^2##
where ##R## is the radius of the Earth and ##T## is the time for one rotation.
##\Delta V \approx g \Delta R##
where ##\Delta R## is the change in radius from the North Pole to the equator, and ##g## is the gravitational acceleration.
So you're saying that
##g \Delta R \approx \frac{1}{2} (\frac{2 \pi R}{T})^2##
We're talking about the geoid here, which is the hypothetical surface of the Earth if it were a perfect fluid (or to very good approximation, all ocean) so the tangential speed has the right relationship to the potential in the weak field approximation. Google for "geoid time dilation" will find some derivations.
Likes FactChecker
I googled it but couldn't spot it. It might be hiding amungst all the GPS articles. Do you know of a specific reference? Is it theoretically exactly equal for some reason?
An argument that I saw from my Googling research was this: Choose a rotating coordinate system in which the Earth is at "rest". In this coordinate system, the "gravitational field" includes both real gravity and centrifugal force. The surface of the ocean is an equipotential surface in this "gravitational field". But mathematically, the gravitational potential ##V## is related to the metric as follows: ##1 + V = \sqrt{g_{00}}##. So equipotential implies equal value for ##g_{00}##. And proper time is related to coordinate time through: ## d\tau = \sqrt{g_{00}} dt## (for a clock at "rest"). So clocks everywhere at sea level have the same proper time.
Likes m4r35n357, Dale, FactChecker and 1 other person
In the rotating frame of reference the centrifugal force points up and the gravitational force points down and the combined force forms a potential. The geoid then is an equipotential surface. Since time dilation is related to the change in potential this equipotential surface is also an “equidilation” surface.
Edit: I see you already found this!
Likes vanhees71, Paul Colby, stevendaryl and 1 other person
Thank you! Very interesting! :smile::smile::smile:
Related to Is a clock on the equator time dilated?
1. What is time dilation?
Time dilation is a phenomenon in Einstein's theory of relativity where time appears to pass at different rates for observers in different reference frames. This means that time can appear to move slower or faster for different objects depending on their relative speeds and gravitational fields.
2. How does being on the equator affect time dilation?
The Earth's rotation causes a slight bulging at the equator, which results in a slightly weaker gravitational pull compared to the poles. This means that time on the equator would appear to pass slightly faster than at the poles, resulting in a negligible difference in time dilation.
3. Does this mean that a clock on the equator will run faster?
Yes, a clock on the equator would run slightly faster compared to a clock at the poles. This is due to the weaker gravitational pull and the faster rotational speed at the equator, which both contribute to a smaller time dilation effect.
4. How much of a difference in time dilation would there be on the equator?
The difference in time dilation between the equator and the poles is extremely small, on the order of nanoseconds. It would not have a noticeable effect on everyday life or technology.
5. Is there any other factor besides the Earth's rotation that affects time dilation at the equator?
The Earth's rotation is the main factor that affects time dilation at the equator. However, other factors such as the Earth's orbit around the sun and its movement within the Milky Way galaxy can also have a very small impact on time dilation at the equator.
