MHB Is \( A \) Isomorphic to \( \dfrac{R<X,Y>}{((X^2+1)X,(X^2+1)Y,YX)} \)?
  • Thread starter Thread starter Fermat1
    Isomorphism
The discussion revolves around proving that the algebra \( A \) of upper triangular matrices is isomorphic to the quotient \( \dfrac{R<X,Y>}{((X^2+1)X,(X^2+1)Y,YX)} \). A proposed homomorphism \( f \) is defined, mapping \( X \) and \( Y \) to specific matrices, but there is confusion regarding the surjectivity of \( f \) and the nature of the entries in \( A \). Clarifications are made that \( a \) and \( b \) can be complex, while \( c \) must be real, and that \( R \) refers to the reals. The conclusion is reached that \( A \) is indeed isomorphic to the specified quotient, leveraging the properties of free algebras and the ideal generated by the elements in question.
Fermat1
let $x=\begin{bmatrix}i&0\\0&0 \end{bmatrix}$ and $y=\begin{bmatrix}0&1\\0&0 \end{bmatrix}$.
Define $A={{\begin{bmatrix}a&b\\0&c\\ \end{bmatrix}}where c\in\mathbb{R}}$
Show that A is isomorphic to $\dfrac{R<X,Y>}{((X^2+1)X),(X^2+1)Y,YX)}$
My work: Define $f:R<X,Y>\implies A$ by $f(X)=x$, $f(Y)=y$, and define $f$ to be an algebra homomorphism. Things to do: Show $(X^2+1)X$ etc. are in the kernel, which I have done.
Show $f$ is surjective, which I haven't been able to do. Finally I would need to show those elements are in fact the whole kernel in order to invoke the first isomorphism theorem
I'm a bit confused...is the domain of $f$: $\Bbb R[X,Y]$, or does $R$ refer to some other ring?
Also, you state that $c \in \Bbb R$, but what about $a,b$?
If indeed all the entries of elements of $A$ are to be real, then $x$, as you have defined it, is not in $A$, so your proposed homomorphism does not have the right co-domain.
What does the original problem actually state? I feel we are missing something, here.
a,b can be complex numbers and yes R is the set of reals. A is a set by the way, not a matrix
Ok, so $A$ is the set of all upper triangular matrices in $\Bbb C_{2 \times 2}$ with real entries in the 2,2 position.
Also, just to clarify, by $\Bbb R\langle X,Y\rangle$ you mean the non-commutative real polynomial ring in two indeterminates, right?
Also, you are taking:
$f(c) = \begin{bmatrix}c&0\\0&c\end{bmatrix}$, yes?
If that is so, then writing:
$a = a_0 + a_1i$
$b = b_0 + b_1i$
we have, for:
$M = \begin{bmatrix}a&b\\0&c\end{bmatrix} \in A$:
$f(c + a_1X + (c - a_0)X^2 + b_0Y + b_1XY) = M$,
which shows $f$ is surjective.
Frankly, I think that's all you need to show, because $R\langle X,Y\rangle$ is *free* in $X$ and $Y$, and $f$ evidently annihilates the set of generators of the ideal, so $A$ IS (isomorphic to) the quotient of the free $\Bbb R$-algebra on two letters modulo the ideal generated by the generating set (using the universal properties of free algebras and quotient rings).
I hope that makes sense to you.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 33 ·
