Is a Matrix Invertible and Have Integer Entries If Its Determinant is 1 or -1?
  • MHB
  • Thread starter Dethrone
  • Tags
    Proof
In summary, we can prove that a matrix $A$ with integer entries is invertible and has an inverse with integer entries if and only if its determinant is equal to 1 or -1. This can be shown by considering the properties of the determinant and the adjugate matrix, which contains all integer entries for $A$. If the determinant is not equal to 1 or -1, then the inverse of $A$ will contain fractional entries, contradicting the assumption that $A$ has only integer entries. Conversely, if the determinant is equal to 1 or -1, then the inverse of $A$ will also have only integer entries, as shown by the properties of the adjugate matrix.
Dethrone
717
Let $A$ be a matrix each of whose entries are integers. Prove that $A$ is invertible and $A^{-1}$ having integer entries if and only if $\text{det}A=1$ or $-1$.
What I have so far is this:
Suppose $A$ is invertible, then $AA^{-1}=I$ and $\text{det}A\cdot \text{det}A^{-1}=1$.
I am not sure how to proceed.
I think I figured it out, but I'm too lazy to type out the formal proof with latex. The forward direction can be proven directly by seeing that if $A$ has integer entries, then the adjugate/adjoint will have integer entries. Furthermore, since $A^{-1}$ has integer entries, $\text{det}A$ must either be 1 or -1. Approaching this by contrapositive, we can see that if $\text{det}A$ is not 1 or -1, then $A^{-1}$ has fractional entries. A contradiction.
The backward direction is just reverse logic. Is that correct?
I agree with the forward direction. \(\displaystyle A^{-1}=\frac{1}{\text{det }(A)} \text{adj }(A)\) and $\text{adj }(A)$ will contain all integers for this particular $A$ (might need to justify this depending on how in depth your prof likes you to go), so clearly \(\displaystyle \frac{1}{\text{det }(A)}\) must be an integer in order for the $A^{-1}$ to contain only integers, and the result follows.
For the backward direction, you are suggesting starting with $\displaystyle {\text{det }(A)}= \pm 1 \implies \frac{1}{\text{det }(A)} \text{adj }(A) $ contains all integer entries $\implies A^{-1}$ contains all integer entries. Right?
I think this proof is solid but saying some words about the adjunct matrix containing all integers would be good because it is a major part of your argument in both directions. :)
Yep, that is precisely what I wanted to say. On paper, I like to be really rigorous and thorough with my explanation, but having to use \text{} each time was too much for me to handle. :p Thanks Jameson!
$\DeclareMathOperator{\adj}{adj}$
Hey Rido! ;)
I don't think the proof is valid yet. What if $\adj A$ contains only even numbers and $\det A = 2$?
Btw, \det already is an operator name, and $\adj$ can be written as \operatorname{adj}, which takes care of proper spacing.
Alternatively, if you type \DeclareMathOperator{\adj}{adj} once (as I did in this post), you can use \adj in the remainder of the post. (Nerd)
(It might be a nice improvement if \adj was predefined in our forum.)Here's a different way to proceed, which does not require \text or \operatorname at all.
Suppose $\det A \ne \pm 1$.
Since $\det A \cdot \det A^{-1} = \det I = 1$, one of them must have a magnitude greater than 1, while the other one must be between 0 and 1.
Is that possible for integer matrices?
Good catch, ILS. You're 100% correct. If all the terms contain a common factor then \(\displaystyle \frac{1}{\text{det }(A)}\) doesn't need to be 1.
Much better idea for the proof as well. :)
Hi ILS! (Cool)
That makes sense! Indeed, since they have integer elements, the determinant must be larger than 1. It could be 0, but then that would violate the fact that $A$ is invertible, so that could not happen.
Seems like $\adj$ is predefined now...:D
It would also be nice if $\operatorname{col} A,\operatorname{row}A, \operatorname{span}A, \operatorname{rref}A$, etc could be predefined too...hehe. Not sure if that would take up too much necessary space, however.
FAQ: Is a Matrix Invertible and Have Integer Entries If Its Determinant is 1 or -1?
What is invertibility in scientific terms?
Invertibility refers to the property of a mathematical function or system that allows it to be reversed or undone. In other words, an invertible function or system has a unique input-output relationship that can be reversed to find the initial input from a given output.
How does invertibility impact scientific research?
Invertibility is a crucial concept in scientific research as it allows for the validation and replication of findings. By being able to reverse a process or function, scientists can ensure that their results are accurate and reproducible.
Can all mathematical functions or systems be invertible?
No, not all mathematical functions or systems are invertible. A function must meet certain criteria, such as being one-to-one (each input has a unique output) and onto (every output has a corresponding input), to be considered invertible.
How is invertibility related to causality in scientific experiments?
Invertibility is closely tied to causality in scientific experiments. By being able to reverse a process or function, scientists can determine the cause of a particular outcome or result.
Are there any real-world applications of invertibility in science?
Yes, invertibility has many practical applications in science, including in fields such as signal processing, cryptography, and data compression. The ability to reverse a process or function is essential in these areas for accurate and efficient data analysis and communication.
