MHB Is a number member of sequence?
  • Thread starter Thread starter cfg
    Member Sequence
The discussion revolves around determining if the numbers 10 and 6 are members of the sequence defined by the equation an(n in subindex)=(1/2)*n^2-3n+5/2 for n ≥ 1. To find this, participants suggest solving the equations derived from setting the sequence equal to these numbers. The quadratic nature of the sequence implies that solutions can be found by analyzing the discriminant for integral roots. The discussion also touches on the recursive definition of the sequence, which adds depth to the analysis. Ultimately, the focus is on solving the equations to confirm membership in the sequence.
cfg
an(n in subindex)=(1/2)*n^2-3n+5/2, when n ≥1
Is number 10 member of that sequence? what about number 6?Create equation to solve it.
If someone can help with this problem please, it will be much appreciated!
Mathematics news on Phys.org
Is that $\frac{n^2}{2}-3n+\frac{5}{2}$?
If so, then if 10 is a member of the sequence, then there is a positive integer n that satisfies $$\frac{n^2}{2}-3n+\frac{5}{2}=10$$
Either find such a solution to the equation (solve for n) or prove that there isn't one. Do the same for 6.
While this may be beyond the scope of what is expected or even needed here, we could observe that since the closed form of the sequence is a quadratic with real coefficients, then the recursive form will come from the characteristic equation:
$$(r-1)^3=r^3-3r^2+3r-1$$
and so the sequence may be defined recursively as:
$$a_{n+3}=3a_{n+2}-3a_{n+1}+a_{n}$$
where:
$$a_1=0,\,a_2=-\frac{3}{2},\,a_3=-2$$
Another thing we might look at is the equation:
$$\frac{n^2-6n+5}{2}=a_n$$
$$n^2-6n+5-2a_n=0$$
If there is going to be an integral root, then the discriminant will be a perfect square, the square of an even number:
$$(-6)^2-4(1)\left(5-2a_n \right)=(2m)^2$$ where $$0\le m\in\mathbb{Z}$$
$$9+2a_n-5=m^2$$
$$4+2a_n=m^2$$
$$2\left(2+a_n \right)=m^2$$
So, we can easily see that when $$a_n=6\implies m=4$$. What about when $a_n=10$?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
