Is a physics/chemistry bachelor a physicist/chemist?
  • Thread starter Gruxg
  • Tags
    Bachelor
In summary, a 3-year grade is not sufficient to consider someone as a physicist/chemist/biologist. However, a physicist is someone who does work in physics, regardless of the degree. A physicist with a PhD can be considered a "physicist," but someone with a bachelor's degree in physics can also be considered a physicist.
Gruxg
41
In my country we do not have an equivalent to the 3-year B.Sc that some coutries have. All the degrees have 4 years, and after that you get the first academical title and then you can do a master if you want (supposedly more specialised).
Perhaps it is only a semantic question, but do you think that a 3-year grade is sufficient to consider someone as a physicist/chemist/biologist?. In the case of physics, it seems to me very little time to cover all the general contents necessary to have an overall view of physics (classical electrodynamics, quantum mechanics, a bit of statistical physics, etc, etc), I guess is its just sufficient for studying "classical" physics: mechanics, a bit of electromagnetism, thermodynamics, some optics...
Is a BSc sufficient to find a work related to the science anywhere?
I believe a physicist is someone who does work in physics, regardless of the degree. If someone has a degree in history but works as a programmer, would you say that person is a historian?
Likes symbolipoint, Dishsoap and Gruxg
Maybe you are right.
But consider for example someone whith a physics doctorate and a good command of physics who work in something not related to physics. He/she is not a physicist?
There are many people with physics degrees, including PhDs, who work as engineers and call themselves as engineers based on their job titles.
Zz.
Likes Gruxg
It is a semantics question.
Technically anyone can call him or herself a "physicist" even without a bachelor's degree in the subject because there in no legal protection of the term as there is with a title like "physician" or "pharmacist." In the latter cases the titles are legally restricted because the state regulates the associated professions.
That said, the most common interpretation of "physicist" is someone with a PhD in the subject who is actively working in the field. If you tell someone on these forums or generally anyone with an academic background that is what you are, then this is what they will tend to assume.
In some cases someone with a bachelor's degree in physics can be considered a "physicist." The Canadian Association of Physicists has a https://www.cap.ca/en/careers/pphys-certificationfor example, which awards that designation with a BSc as a minimum and a few years of experience working in a context where physics principles are applied. (It's a rather open definition, from what I remember.)
I'm not sure about "chemist" but I suspect it follows the same rules - or lack thereof.
Likes Gruxg
Such a person is not a physicist. He once was a physicist, but is no longer one.
Likes Gruxg
Related to Is a physics/chemistry bachelor a physicist/chemist?
1. What is the difference between a physics/chemistry bachelor and a physicist/chemist?
A physics/chemistry bachelor is a person who has completed an undergraduate degree program in either physics or chemistry. This degree typically covers a broad range of topics within the field, and the individual may not have specialized in any specific area. A physicist/chemist, on the other hand, is someone who has completed a graduate degree in either physics or chemistry and has specialized in a specific area of research or practice.
2. Can a person with a physics/chemistry bachelor's degree be called a physicist/chemist?
Technically, yes, a person with a physics/chemistry bachelor's degree can be called a physicist/chemist. However, they may not have the same level of knowledge and expertise as someone with a graduate degree in the field. It is more accurate to refer to them as a physics/chemistry bachelor or a physics/chemistry graduate.
3. What career options are available for someone with a physics/chemistry bachelor's degree?
A person with a physics/chemistry bachelor's degree can pursue a variety of careers in industries such as research and development, healthcare, energy, and technology. They may work as laboratory technicians, quality control analysts, data analysts, or science educators.
4. Is a physics/chemistry bachelor's degree sufficient for research or academic positions?
No, a physics/chemistry bachelor's degree is not typically sufficient for research or academic positions. These positions usually require a graduate degree, such as a master's or a Ph.D., in order to have the necessary knowledge and skills to conduct research and teach at a university level.
5. Can a person with a physics/chemistry bachelor's degree pursue a career in a different field?
Yes, a person with a physics/chemistry bachelor's degree can pursue a career in a different field. The skills and knowledge gained through this degree, such as critical thinking, problem-solving, and data analysis, are transferable and can be applied to various industries, including finance, law, and consulting.
  • STEM Academic Advising
