Is a pure state a kind of mixed states?
In summary, pure states and mixed states can both be represented using density operators. The quantum jump by observation works for both types of states. The postulates II.4 and II.5 on p9 of the tutorial on quantum states, measurements, and operations and Eq 3 and 4 of "No Information Without Disturbance" by Paul Busch explain this further. It is important to note that pure states are not represented by unit vectors in Hilbert space, but by projection operators. This has significant consequences, including the existence of fermions.
sweet springs
1,223
75
Hi.
1. Does a pure state belong to mixed states
[tex]\hat{\rho}=\sum_k p_k|\psi_k><\psi_k|[/tex] where ##p_k=1## for k=i and otherwise 0 ?
2. Does quantum jump by observation work for both mixed and pure states ?
Your teachings will be appreciated.
If we use density operators to represent states, both pure states and mixed states can be represented in the same formalism. In the usual terminology, pure states are not mixed states.
The quantum jump by observation works for both pure and mixed states.
https://arxiv.org/abs/1110.6815
The modern tools of quantum mechanics (A tutorial on quantum states, measurements, and operations)
Matteo G. A. Paris
See postulates II.4 and II.5 on p9
https://arxiv.org/abs/0706.3526
"No Information Without Disturbance": Quantum Limitations of Measurement
Paul Busch
See Eq 3 and 4
Likes vanhees71
I will read them fully. Thanks a lot.
I thought pure states always take place after observation of both pure and mixed states. II5 tells us that mixed states appear if we do not record observed values. It is very interesting that recording or memory matters physics.
You prepare a pure state, e.g., by performing a simultaneous von-Neumann-filter measurement of a complete set of observables, and indeed states are most conveniently described by statistical operators, which are of the form as you wrote. They are self-adjoint positive semi-definite operators with trace 1. The pure states are exactly the projection operators, where exactly one of the ##p_k## is 1 and thus all others 0.
One cannot overstress the importance of the fact that pure states are NOT represented by unit vectors in Hilbert space but by the corresponding projection operators or, equivalently, unit rays in Hilbert space. In other words overall phase factors are not physical, and this has a lot of important consequences. One of the most important is that you can have half-integer spin and fermions. Our entire existence as living beings rests on the existence of fermions!
Related to Is a pure state a kind of mixed states?
1. What is a pure state?
A pure state is a state in which a system is described by a single, definite quantum state, meaning that it has a specific set of properties and characteristics. It is also known as a quantum state or a wave function.
2. What is a mixed state?
A mixed state is a state in which a system is described by a statistical mixture of multiple quantum states. This means that the system has more than one possible set of properties and characteristics and cannot be described by a single, definite quantum state.
3. How is a pure state different from a mixed state?
A pure state is a single, definite quantum state whereas a mixed state is a statistical mixture of multiple quantum states. This means that a pure state has specific properties and characteristics, while a mixed state has a range of possible properties and characteristics.
4. Can a pure state become a mixed state?
No, a pure state cannot become a mixed state. Pure states and mixed states are fundamentally different and cannot transform into one another. However, a pure state can become a mixed state through the process of decoherence, where interactions with the environment cause the system to lose its quantum coherence and behave classically.
5. Why is it important to distinguish between pure states and mixed states?
It is important to distinguish between pure states and mixed states because they have different physical properties and behaviors. Pure states are used to describe isolated systems and are essential for understanding quantum phenomena, while mixed states are used to describe open systems and are essential for studying the effects of interactions with the environment.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
