Is a Quantum-Controlled Mirror Possible?
In summary, the conversation discusses the possibility of a quantum-controlled mirror that could reflect or transmit light based on a quantum event, similar to a quantum-controlled beam splitter. This could potentially lead to interference between beams of light passing through the mirror. It is suggested that any device that selects a path, such as a beam bender, could also be controlled by a quantum event. Further experiments involving splitting the photons and observing interference fringes are proposed.
Erik Ayer
75
I was reading a pdf that mentioned a quantum-controlled beam splitter and wondered whether a quantum-controlled mirror exists. In the beam-splitter case, the beam splitter could either be present or absent, such that path information of photons was either preserved or not. It was controlled with a quantum event so that it's presence or absence was in a state of superposition.
For a mirror, could it be controlled by a quantum event such that it was in a superposition state of being reflective and transparent? If so, a beam could pass through it, be reflected back together, and form interference. It seems like isolation would be critical to keep the state from collapsing.
A beam splitter is doing that - it acts as mirror or let's light through, or does both at the same time.
It would be interesting to see the source for the beam splitter experiment.
Yes, a beam splitter splits the beam, but it's on an individual photon basis. If a mirror were controlled to reflect or transmit based on some quantum event, then a bunch of photons would either be reflected or transmitted. If no determination of the setting of the mirror were made (the information was not available, even in principle), then that clot of photons could then be interfered. However, if one photons was found to have been reflected, then they all would have been reflected. Would that entangle all the photons with the mirror, or possibly with the event controlling the mirror?
It would have to be a mirror, either. Anything that selects a path, like by "bending" a beam either slightly left or right, could do this as long as the "switch" were determined by a quantum event. If a light source were dimmed down to the point where one photon per second was sent, then the state of the switch could be set by the polarization in some axis, each second.
The interesting to do next would be to split the photons coming out such that some go to an interferometer to generate interference fringes, and some go elsewhere. The "elsewhere" photons would carry information as to the state of the switch and could then collapse the state to reflect/transmit or bend-left/bend-right, or that information could be erased by focusing them onto one spot on a brick (all physics experiments should involve a brick).
Related to Is a Quantum-Controlled Mirror Possible?
What is a quantum-controlled mirror?
A quantum-controlled mirror is a device that can reflect or transmit quantum particles, such as photons, based on the state of another quantum system. It acts as a switch for quantum information and can be controlled by manipulating the state of the controlling system.
How does a quantum-controlled mirror work?
A quantum-controlled mirror works by using the principles of quantum superposition and entanglement. The controlling system is prepared in a superposition of two states, and upon interacting with the mirror, it can either reflect or transmit the quantum particles based on the specific state it is in. This allows for precise control over the behavior of the particles.
What are the potential applications of a quantum-controlled mirror?
A quantum-controlled mirror has many potential applications in quantum technologies, such as quantum computing and quantum communication. It can also be used in precision measurements and sensing, as well as in quantum simulations and experiments.
What are the challenges in building a quantum-controlled mirror?
One of the main challenges in building a quantum-controlled mirror is maintaining the coherence and stability of the controlling system. Any external interference or noise can disrupt the delicate quantum states and affect the performance of the mirror. Another challenge is scaling up the technology to work with larger and more complex quantum systems.
How is a quantum-controlled mirror different from a traditional mirror?
A traditional mirror reflects light based on its physical properties, such as reflectivity and angle of incidence. In contrast, a quantum-controlled mirror reflects or transmits quantum particles based on the state of another quantum system. This allows for much more precise control over the behavior of the particles, making it a powerful tool in quantum information processing.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
