A Is a solution of a differential equation a function of its parameters?
Meaning
Hi everyone,
Imagine I have a system of linear differential equations, e.g. the Maxwell equations.
Imagine my input variables are the conductivity $\sigma$. Is it correct from the mathematical point of view to say that the electric field solution, $E$, is a function of sigma in general, E(r,t,sigma)?
Thank you
Yes. Unless something weird is going on, the value of the solution at a particular point and time is determined by the parameters and the initial and boundary conditions.
Thank you
Basically, any differential equation describes a family of curves, surfaces, volumes...
It's the boundary conditions and initial parameters that fix it to one curve, surface or volume...
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
