Is all correlation related to quantum entanglement?
In summary, it is possible to have correlation without entanglement, as demonstrated by an ordinary coin. Entanglement only exists between states that are superposed, making it a precisely defined mathematical property of the wave function. Therefore, superposition is necessary to have entanglement.
friend
1,452
In other words, it seems that if you have entanglement, then you have correlation (of measured properties). But is it true that if you have correlation, then you have quantum entanglement? Classically, correlation is between macro-events. But macro-events are made of micro-events. So is classical correlation the classical limit of quantum entanglement?
Thinking further, we can only measure something if there is correlation. e.g. correlation between the needle on the meter and the voltage in the circuit. Even a quantum measurement only exists if there is a correlation. For it takes an interaction to make a measurement, and we only know something about the particle being measured because it is somehow correlated with the particles interacting with it. So can you have correlation without entanglement? Isn't correlation the measure of entanglement (always)?
Thanks.
It is easy to produce correlation without entanglement. An ordinary coin provides a good example: observations of heads on one face are strongly correlated with observations of tails on the other side.
Are you saying that the heads on one side are not entangled with the tails on the other when they are both part of the whole coin? I suppose there is no superposition. Does entanglement only exist between states that are superposed?
Yes, I am saying they are not entangled. Entanglement is a precisely defined mathematical property of the wave function, and a tossed coin doesn't have that property.
I suppose there is no superposition. Must there be superposition to get entanglement?
Yes. That's part of the definition.
Related to Is all correlation related to quantum entanglement?
1. What is correlation in science?
Correlation in science refers to the relationship between two variables, where a change in one variable can cause a change in the other. It is often measured using statistical methods such as correlation coefficients.
2. What is quantum entanglement?
Quantum entanglement is a phenomenon in quantum mechanics where two or more particles become connected in a way that their physical properties are dependent on each other, even when separated by large distances.
3. Is all correlation related to quantum entanglement?
No, correlation can occur in various systems and does not necessarily involve quantum entanglement. It can also be observed in classical systems and can be caused by factors such as causality or coincidence.
4. How is quantum entanglement related to correlation?
Quantum entanglement can lead to a strong correlation between two particles, as any measurement made on one particle can instantly affect the state of the other particle, even if they are separated by large distances. This phenomenon is known as quantum non-locality.
5. What are the implications of quantum entanglement for correlation in science?
The existence of quantum entanglement challenges our understanding of causality and locality, and has potential applications in quantum computing and communication. It also highlights the importance of considering quantum effects in studying correlations in various systems.
