Is ∼ an Equivalence Relation on the Power Set of a Finite Set?
That is, \begin{pmatrix}n \\ m\end{pmatrix}= n!/(m!(n-m)!). In this case, n= 4 so there are 6 subsets that contain 2 members, \begin{pmatrix}4 \\ 2\end{pmatrix}= 4!/2!(2!)= 24/(2*2)= 6. The 16 subsets are: {}, {1}, {2}, {3}, {4}, {1, 2}, {1, 3}, {1, 4}, {2, 3}, {2, 4}, {3, 4}, {1, 2, 3
kathrynag
598
Let S be a finite set and denote by [tex]2^{S}[/tex] = {A|A ⊆ S} the set of all subsets of S. Define
a relation ∼ on [tex]2^{S}[/tex] by A ∼ B if and only if A and B have the same number of elements.
(a) Show that ∼ is an equivalence relation on [tex]2^{S}[/tex].
(b) Let S = {1, 2, 3, 4}. List the (sixteen) elements of [tex]2^{S}[/tex] and explicitly list the
elements in each equivalence class determined by ∼.
I started by determining what an equivalence relation is:
i. (a,a) is in ~
ii. For all (a,b) in S, if (a,b) is in ~, then (b,a) is in ~
iii. For all a,b,c in S, if (a,b) is in ~ and (b,c) is in ~, then (a,c) is in ~.
I have trouble using the definitions.
I tried doing something like [tex]2^{a}[/tex]=[tex]2^{a}[/tex]
Just follow the definitions, the relation defined was: "have the same number of elements"
So in order to check this: (a,a) is in ~
you just need to check: do 'a' and 'a' have the same number of elements
etc.(also, you meant: ii. For all a and b in [tex]2^{S}[/tex], if (a,b) is in ~, then (b,a) is in ~... as the relation was defined on [tex]2^{S}[/tex], not on S)
a and a have the same number of elements since a has the same number of elements as itself.
If a and b have the same number of elements, b and a have the same number of elements.
If a and b have the same number of elements and a and c have the same number of elements, then since a has the same number of element of b and c, b must have the same number of elements as c.
Ok for part b)
elements are 2, 4, 8, 16, but only 2, 4 are in S. I don't see how to get 16 elements.
No, for a set, S, the notation "[itex]2^S[/itex]" means "the collection of all subsets of S". That notation is used because if set S contains n elements then it has [itex]2^4[/itex] subsets. {1, 2, 3, 4} has 4 members so it has [itex]2^4= 16[/itex] subsets.
The only subset that has 0 members is the empty set.
Their are 4 subsets that contain 1 member: {1}, {2}, {3}, {4}.
There are 6 subsets that contain 2 members, 4 that contain 3 members, and 1 that contains 4 members.
In general, if a set contains n members, there are the binomial coefficient,
[tex]\begin{pmatrix}n \\ m\end{pmatrix}[/tex]
subsets that contain m members.
FAQ: Is ∼ an Equivalence Relation on the Power Set of a Finite Set?
What is an equivalence relation?
An equivalence relation is a mathematical concept that describes a relationship between elements of a set. It is a relation that is reflexive, symmetric, and transitive.
How do you prove that a relation is an equivalence relation?
To prove that a relation is an equivalence relation, you need to show that it satisfies the three properties of reflexivity, symmetry, and transitivity. This can be done by providing specific examples that demonstrate each property.
What is the difference between an equivalence relation and an equality relation?
An equivalence relation is a type of relation that compares elements of a set, while an equality relation compares two elements and determines if they are exactly the same. An equivalence relation is a more general concept than an equality relation.
What are some examples of equivalence relations?
Some common examples of equivalence relations include equality, congruence, and similarity. In set theory, the relation of equivalence classes is also an example of an equivalence relation.
Why are equivalence relations important in mathematics?
Equivalence relations are important in mathematics because they help us understand the relationships between elements of a set and can be used to simplify and solve complex problems. They also play a crucial role in different branches of mathematics, such as group theory and topology.
