Is an invisible LED mouse more accurate than one with a red LED?
  • Thread starter Thread starter Ephant
    Led Optics
The Logitech M557 mouse, equipped with invisible LED technology, performs well on various surfaces, including white bond paper, but experiences button instability due to dust accumulation. In contrast, the A4tech 620D with red LED struggles on the same paper but operates smoothly on a cloth mouse pad. The accuracy of optical mice may depend on the specific model and the brightness of the surface used, rather than solely on the color of the LED. The spectral response of the sensor plays a crucial role, as infrared light has longer wavelengths that can affect spatial resolution. Historically, optical mice utilize a basic sensor design, and surface texture can significantly impact cursor movement. Overall, while the type of LED may influence performance, the construction and design of the mouse are more critical factors.
Ephant
I have a bluetooth Logitech M557 mouse with invisible led (it's written "invisible optics underneath) that I had for 5 years and I could use on any surface most often on a pure white bond paper. It can move smoothly. My only problem at present is the buttons are not so stable now due to dusts collected inside the switch (which I couldn't remove totally) or other problems.
I bought an A4tech 620D with red led. It has difficulty moving smooth in the bond paper. When I bought a mouse cloth-like pad. It can finally move smoothly.
Are white led generallly more accurate? Why? Or is it due to the unique model or build of the Logitech M557?
Computer science news on Phys.org
It probably depends more on which and how much brightener is used in the paper than on the color of the light. That said, the spectral response of the sensor could make the difference.(Infrared has a longer wavelength than visible light so that would reduce the spatial resolution.)
The popular optical mouse, originated by Hewlett-Packard (HP) several decades ago as I recall, consists of a 3x3 photosensor (a 9 pixel camera) and some processing. The times I've used a sheet of paper as a mouse pad, sometimes it worked fine and sometimes it didn't, it was also direction sensitive. My desktop is white with a little bit of texture, except for a shiny spot where I used the mouse for a while. I now use a mouse pad because the cursor movement will sometimes get erratic on that shiny area -- besides, a mouse pad adds a little bit of friction that makes the mouse more controllable; without that friction it's like walking on ice or a soapy tile floor!
Well, I probably didn't answer your question, but at least now you have a little more information, and history!
I just tried the mouse on a manilla envelope and got intermittent movement on various areas of the envelope.
Cheers,
Tom
As white is the composite of different wavelengths, each as a possible way to sense the movements of those small fluctuations in intensity (compared to the standard monochrome, of any colour), it might be.
But in general, the build of the actual device will be the most important.
I didn't mean white led. I mean invisible IR led.
You wrote white there.
IR is just another monochrome.
It was a typo. I meant invisible.
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
