Is anyone here familiar with TextPad?
  • Thread starter pmb_phy
In summary, Pete says that TextPad is an editor for text (ASCII, txt, html), but he's having trouble using it with the Java environment. He recommends checking to see if a class has been defined and using the "Compile Java" and "Run Java" macros if necessary. Warren is not familiar with Java, but he knows that one has to be sure a class of documents is defined when saving a particular class with TextPad. He suggests looking at what the "Compile Java" and "Run Java" macros actually do.
pmb_phy
2,952
Is anyone here familiar with TextPad? I'm trying to use it as an interface for editing and running Java but I'm having problems. I don't know how to set it up to work with the Java environment.
Thanks
Pete
Computer science news on Phys.org
I use TextPad as a text (ASCII, txt, html) editor, except for Word documents.
Try going into Configure - Preference - and find Document Classes. One of the default classes is Java.
You might also have to set up Associated Files and File Name Filters.
I have no idea what kind of problem you're experiencing. There's really no such thing as a "Java environment." TextPad is a text editor. You can configure some macros to run command-line programs to compile and run your code, but, apart from that, there is no Java environment. Perhaps you could be a little more specific with your question?
- Warren
I use TextPad as an editor too. I used it a few years ago when I was learning C++ and it was a great tool. But now I can't figure out what I'm doing wrong. E.g. I wrote this piece of code
// Fig. 2.1: Welcome1.java.
// A first program in Java.
public class Welcome1 {
// main method begins execution of Java application
public static void main( String args[] )
System.out.println( "Welcome to Java Programming!" );
} // end main method
} // end class Welcome1
Then I selected "Tools->Compile Java" and it took a few seconds and then in another window that popped up behind the code window and read
"Tool completed successfully"
Then I selected "Tools->Compile Java Application" and a DOS window popped up and said
Exception in thread "main" java.lang.NoClassDefFoundError: Welcome1
Press any key to continue . . .
Seems to me that there are some pathways that the computer can't find/doesn't know about. What do I do at this point? I'm not even sure that its compiling. :frown:
Pete
I am not versed in Java, so hopefully chroot can help. I don't know if the syntax of your code is correct or not, but I would wonder if Textpad is using the correct compilation or not, or if it is inserting stuff (equivalent of hidden or control codes?) that is unwanted.
But I am familiar with some TextPad's idiosyncracies. One has to be sure a class of documents is defined and is used when saving a particular class. I am not sure if that is what is happening here. Maybe you found a new one.
I'd suggest looking at what the "Compile Java" and "Run Java" macros actually do, and edit them if necessary.
- Warren
FAQ: Is anyone here familiar with TextPad?
What is TextPad?
TextPad is a text editor software that is designed for Windows operating system. It allows users to create and edit plain text files, as well as write programming codes in various languages.
Is TextPad a free software?
No, TextPad is not a free software. It has a free trial version but the full version requires a one-time payment.
Can I use TextPad on a Mac or Linux computer?
No, TextPad is only compatible with Windows operating system. However, there are similar text editors available for Mac and Linux such as TextMate and gedit.
What are the features of TextPad?
TextPad has various features including syntax highlighting for different programming languages, regular expression search and replace, customizable keyboard shortcuts, and the ability to work with multiple files simultaneously.
Is TextPad suitable for beginners?
While TextPad may seem overwhelming for beginners, it is a great tool for learning programming languages as it offers syntax highlighting and other helpful features. However, for simple text editing, there may be other easier and more user-friendly options available.
10K
