Is Carnot engine the only reversible engine?
In summary: In this case, the heat supplied is determined by the temperature difference between the hottest and coldest reservoir (or the two reservoirs at the same temperature). So, the efficiency of an Otto cycle is simply the ratio of the work done to the heat supplied.
kelvin490
Is Carnot engine the only form of reversible engine? Is it possible to have a different form of reversible engine that goes through different processes?
For a standard Otto cycle working with ideal gas, theoretically the two processes involving isochoric pressure change can be reversible processes. Does it mean that the Otto cycle can also have same efficiency as Carnot cycle? Since temperature of the working fluid is changing during isochoric pressure change, does it mean there are infinite number of heat reservoirs being used at different temperatures so that there is no finite temperature difference at every point of the isochoric process?
Science news on Phys.org
The second law of thermodynamics states that the entropy of the universe continuously goes on increasing. Even though the system may arrive at the same state after every cycle, the heat dissipated to the surroundings during the isochoric expansion increases the entropy of the surroundings. For the Otto cycle to be reversible, it would have to violate the second law.
What if we keep on replacing different temperature reservoir from time to time? If Otto cycle is irreversible, we cannot even draw it on the P-V diagram because the isochoric pressure increase/decrease are not quasi-equilibrium process.
Why not? Sure we can draw it on a P-V diagram. An irreversible process is just one which permantly changes surroundings. You cannot come back to the stage that was prevalent before the cycle took place.
The answer to all your questions is YES. You have analyzed the situation flawlessly. Very nicely done. Of course, the combined change in entropy of the two sets of reservoirs will turn out to be zero.
Chet
Likes kelvin490
Chet
Thank you. I have one further question. How to compare the efficiency between a Carnot engine and an ideal Otto engine? As mentioned before in an ideal Otto engine there are infinite number of heat reservoirs being used at different temperatures so that there is no finite temperature difference at every point of the isochoric process. Carnot cycle involves only two reservoirs so it's easy to calculate the efficiency. For an ideal Otto cycle many reservoirs involved so I wonder what's the basis of comparison?
Excellent questions. For the Otto cycle, you can of course model it yourself to derive an equation for the efficiency, or you can check out this link: http://en.wikipedia.org/wiki/Otto_cycle. In this link, they do the analysis for you. If it were me and I really wanted to get some practice, I would model it myself; otherwise, I would just see what they do in the link.
Chet
Likes kelvin490
For calculating the efficiency of an Otto cycle, use the basic principle of efficiency. How much was the heat input, how much of it was converted to work and how much heat was wasted. You can get an equation in the form of 'T'.
Likes kelvin490
Agree. But I think we can only get the equation in terms of ratio of T instead of the exact temperature, since there are numbers of reservoirs and we don't have the criteria for selecting one of them as a representative heat reservoir. Is that correct?
What do they end up with in the Wiki article?
Likes kelvin490
You're right. You get it as a ratio of temperatures. But The ratio is of temperatures at the start and end of a process. The infinite number of temperature reservoirs is a concept used to explain the process. Don't be stuck on that.
Likes kelvin490
Oh, yes. They express it in terms of changes in internal energy first and express in terms of initial and final temperatures. Thanks a lot.
Related to Is Carnot engine the only reversible engine?
1. What is a Carnot engine?
A Carnot engine is a theoretical engine that operates on the Carnot cycle, which is a reversible thermodynamic cycle. It consists of two isothermal processes and two adiabatic processes, and it is used to model the maximum possible efficiency of a heat engine.
2. What does it mean for an engine to be reversible?
A reversible engine is one that can run in both forward and reverse directions without any energy losses. This means that the system can be returned to its original state after completing a cycle, and there is no net change in the entropy of the system.
3. Is the Carnot engine the only reversible engine?
No, the Carnot engine is not the only reversible engine. Other reversible engines include the Stirling engine and the Ericsson engine, which operate on different thermodynamic cycles.
4. Why is the Carnot engine considered to be the most efficient engine?
The Carnot engine is considered to be the most efficient engine because it operates on the Carnot cycle, which represents the maximum theoretical efficiency of a heat engine. This means that no other engine can have a higher efficiency than a Carnot engine.
5. Can a Carnot engine exist in reality?
No, a Carnot engine cannot exist in reality because it is a theoretical idealized engine that does not account for practical limitations such as friction and heat losses. However, the Carnot cycle can be used as a standard for comparing the efficiencies of real engines.
  • Thermodynamics
12K
