- #36
bernhard.rothenstein
- 991
- 1
doppler and his relatives
Interesting point of view. Do you think that performing a given experiment in a given inertial frame we could obtain results which are conflicting with Newton and Galileo. Say the relationship between the proper mass and the relativistic mass (accept please that concept). We obtain some experimental results which can be plotted (m/m(0) as a function of u/c) looking for a function which reproduces best the experimental results. Extrapolation of the experimental results shows that they are best expressed by m=m(0)/((1-uu/cc)^1/2. (1) Consider three inertial reference frame I,I' and I(0). I(0) is the rest frame of the particle that moves with speed u relative to I with velocity u' relative to I, I' moving with V relative to I. Apply (1) from I and I'. Eliminate m(0) between the eqaution you obtain and express its right side as a function of u' only via the addition law of relativistic velocities obtaining the transformation equations for momentum and mass. Of course the same approach can be used in the case of many other relativistic effects. Do you think that such an approach presents some pedagogical advantages? IMHO the addition law of relativistic velocities can be derived without using the LT.
MeJennifer said:You completely mix up theory and experiment here.
Doppler effects are phenomena of nature. By a set of experiments we can conclude that the Lorentz transforms are in accordance with experiment, as is the case with the theory of relativity.
