Is concentrated HCl (12M) a liquid and a gas?
In summary, concentrated hydrochloric acid (12M) is a solution that can produce dangerous acid fumes, similar to dry ice in water but not as much vapor. It is important to handle it with caution to avoid harm.
AMan24
58
I just remembered that in my lab from a few months ago, the 12M HCl we used was "evaporating" or producing gas, similar to dry ice in water but no where near as much vapor. I'm just curious, is concentrated HCl usually like that or was the acid contaminated?
Chemistry news on Phys.org
"Is concentrated HCl (12M) a liquid and a gas?" Neither, its a solution.:wink:
All liquids, even much below the boiling point, will be combined with a vapor phase, where molecules will go into the surrounding gas (although in many cases the vapor pressure can be quite low).
With concentrated hydrochloric acid, you end up with nasty acid fumes that you should not breathe. They can do serious damage to the respiratory system.
Likes gracy and AMan24
Related to Is concentrated HCl (12M) a liquid and a gas?
1. What is concentrated HCl (12M)?
Concentrated HCl (12M) is a solution of hydrochloric acid in water. The "12M" refers to the molarity, or concentration, of the solution, which means that it contains 12 moles of hydrochloric acid per liter of solution.
2. Is concentrated HCl (12M) a liquid or a gas?
Concentrated HCl (12M) is a liquid at room temperature and pressure. It only becomes a gas at very high temperatures or when it is exposed to air, as it reacts with the water vapor in the air to form hydrogen chloride gas.
3. What are the properties of concentrated HCl (12M)?
Concentrated HCl (12M) is a clear, colorless liquid with a pungent odor. It is highly corrosive and can cause burns if it comes into contact with skin or eyes. It is also a strong acid and can react with many substances, often releasing toxic gases.
4. How is concentrated HCl (12M) used in science?
Concentrated HCl (12M) is commonly used in chemistry labs for various purposes, such as in titrations, pH adjustments, and synthesis reactions. It is also used in industrial processes, such as in the production of PVC, and in household cleaning products.
5. Are there any safety precautions to take when handling concentrated HCl (12M)?
Yes, concentrated HCl (12M) is a dangerous substance and should be handled with caution. Always wear protective equipment, such as gloves and goggles, when working with it. It should also be stored in a well-ventilated area, as it can release toxic fumes. In case of accidental exposure, immediately rinse the affected area with water and seek medical attention.
31K
