Is constitutive equation for piezo wrong?
  • Thread starter athosanian
  • Tags
    Piezo
In summary, the linear constitutive equation accurately describes piezo behavior in most cases, as it shows the relationship between electric field and polarization. However, in certain conditions where the piezo disk is short circuited and placed freely on a table, the linear equation may not hold true as there is no external force acting on the disk. In these cases, the use of a nonlinear constitutive equation, which takes into account the initial value of polarization, may be necessary. Overall, the linear constitutive equation is still a valid representation of piezo behavior in general conditions.
athosanian
67
the linear constitutive equation describes piezo behavior. See wiki. But I can find an example in which linear relationship may not satisfy. Given a piezo disk wih polarization in thickness direction and upper and bottom surface as electrodes. I just short circuit the up and bottom surface and put it freely on the table. In such a condition, E=0 in the piezo no doubtly, stress T=0 also, because I do not put any force on it. Then from constitutive equation P=0. But not forget there is spontaneous polarization in disk, so P should not be zero, it has a initial value!
Ok, can we say the linear constitutive equation is wrong?
No, because it is true in general condition. The linear constitutive equation only say the relation between E and P, it dose not tell us what is the initial value of P. So here we can use nonlinear constitutive equation to include the initial value of P. So, we can say that in piezo materials, the linear constitutive equation describes the piezo behavior in general condition, and nonlinear constitutive equation may be needed when we consider the initial value of polarization.
Related to Is constitutive equation for piezo wrong?
1. What is a constitutive equation for piezo?
A constitutive equation for piezo is a mathematical relationship that describes the behavior of a piezoelectric material. It relates the stress and strain of the material to the applied electric field.
2. Is the constitutive equation for piezo wrong?
There is ongoing research and debate about the accuracy of constitutive equations for piezoelectric materials. Some scientists argue that the equations currently used may not fully capture the behavior of these materials, while others believe that they are accurate enough for practical applications.
3. How is the constitutive equation for piezo derived?
The constitutive equation for piezo is typically derived from a combination of fundamental physical principles and experimental data. It may also be refined and modified based on new research and discoveries about the behavior of piezoelectric materials.
4. Can the constitutive equation for piezo be applied to all piezoelectric materials?
No, the constitutive equation for piezo may not be applicable to all types of piezoelectric materials. Different materials may exhibit unique behaviors and require their own specific equations to accurately describe their properties.
5. Why is understanding the constitutive equation for piezo important?
Understanding the constitutive equation for piezo is crucial for developing and improving the design of piezoelectric devices, which have a wide range of applications in various industries such as medical, automotive, and aerospace. It also allows scientists to better understand the behavior of these materials and potentially discover new properties and applications.
