- #36
The Wizard
@ jack action,
the energy produced by the cars powertrain propels the vehicle over the road surface. Depending on a large number of factors, size of tyre, tread pattern, road surface material, gradient, engine output, gearing, use of accessories define how much energy is required to achieve a given speed and maintain it.
As the vehicle is driven the tyres create friction between the road surface and the tyre which produces heat. The vehicle also creates another power source and that is weight which presses down on the road surface causing Deflection. This deflection has nothing to do with heat of any kind, it is a simple mechanical reaction to the force being applied from above. If the force being applied already exceeds the force required to move a sub-component a minimal amount of 0.1mm it is a zero rated byproduct.
The idea of using the Piezo is the Zero emissions, by using a fuel based generator you have Co² emissions and noise.
