Is DNA altered before transcription takes place?
  • Thread starter fatima_a
  • Tags
    dna
In summary, DNA and RNA both undergo alterations, but in different ways. RNA can have its sequence modified and chemical modifications added, while DNA's modifications occur through changes in the proteins that package it. These modifications help with the process of transcription, allowing RNA polymerase to access the DNA for transcription.
fatima_a
24
I though the mRNA was altered and stuff before the final protein product was made, but is DNA also altered because it's like a protection mechanism or something?
thanks
DNA gets altered, but not in the same way that RNA gets altered.
In RNA, the actual sequence of the RNA can get modified (e.g. introns can get removed and a poly(A) tail gets added) and the 5' end of the RNA gets chemically modified by the addition of a cap.
The modifications to DNA that occur prior to transcription do not actually alter the chemical structure of the DNA but instead alter the proteins that package the DNA. In eukaryotes, DNA gets wrapped around proteins called histone proteins to form structures called nucleosomes. The wrapping of the DNA into nucleosomes is one reason why we can fit two meters of DNA into about an approximately six-micron-wide nucleus. However, for RNA polymerase to be able to begin transcribing the DNA, the DNA must be unwound from the nucleosomes. In this process, the histone proteins get chemically modified by enzymes called histone modifying enzymes. These chemical modifications act to help recruit other factors to that aid in transcription. Another class of enzymes, the ATP-dependent chromatin remodeling enzymes, also get recruited and help by removing the histone proteins from the promoter region, giving RNA polymerase access to the DNA.
wow thank you so much that was really very very helpful. i finally understand what my prof meant
FAQ: Is DNA altered before transcription takes place?
What is transcription?
Transcription is the process by which genetic information stored in DNA is copied into a molecule called RNA. This RNA serves as a template for protein synthesis.
How is DNA altered before transcription takes place?
DNA can be altered through a process called DNA methylation, where certain chemical groups are added to the DNA sequence. This can affect gene expression and ultimately impact the transcription process.
Why is DNA altered before transcription?
DNA is altered before transcription to control which genes are expressed and to what extent. This allows for proper regulation of cellular processes and ensures that the correct proteins are produced.
What factors can influence DNA alteration before transcription?
Environmental factors, such as exposure to certain chemicals or radiation, can cause DNA alterations. Additionally, errors during DNA replication can also lead to changes in the DNA sequence.
Can DNA alterations before transcription be reversed?
In some cases, DNA alterations can be reversed through processes like DNA repair mechanisms. However, some alterations can be permanent and may affect gene expression and protein production permanently.
33K
