Is dr/dt Always Perpendicular to r for a Unit Vector r(t)?
In summary: So, if r is always 1, then either \vec{r}=x+y+z=constant, or\vec{r}=r^2=constant. If r changes with time, then dr/dt would need to be perpendicular to r in order for the equation to still hold.
Liquidxlax
322
4. Let r=r(t) be a vector whose length is always 1 (it may vary in direction). Prove that either r is a constant vector or dr/dt is perpendicular to r. hit: differentiate r.r
basic derivatives with respect to t for velocity and acceleration
r = 1 = x + y + z
df = d(r.r) = 2x(df/dx) + 2y(df/dy) + 2z(df/dz)
don't have notes on it yets, so I'm not sure where to go from here.
One can write [itex] \vec{r} = r \hat{r} [/itex]. You are given that the length is always 1, so what can you conclude about r?
Then note that [itex] \vec{r} \cdot \vec{r} = r \hat{r} \cdot r \hat{r} = r^2 [/itex]. Insert the value of r you figured out above, and differentiate this expression with respect to time. You should end up with "thing1 dot thing2 = thing3". What can you conclude about either thing1 or thing2?
I presume that by "r= x+ y+ z" you mean
[tex]\vec{r}= x\vec{i}+ y\vec{j}+ z\vec{k}[/tex]
but then that cannot be equal to the number 1!
In any case, you don't want to reduce to components.
Product rule:
[tex]\frac{d \vec{r}\cdot\vec{r}}{dt}= \frac{d\vec{r}}{dt}\cdot\vec{r}+ \vec{r}\cdot\frac{d\vec{r}}{dt}= \frac{d(1)}{dt}= 0[/tex]
Product rule:
okay, thanks that seems to make sense
FAQ: Is dr/dt Always Perpendicular to r for a Unit Vector r(t)?
What is vector analysis?
Vector analysis, also known as vector calculus, is a branch of mathematics that deals with vector quantities and their operations in multiple dimensions. It involves the use of mathematical tools such as derivatives, integrals, and gradients to analyze and manipulate vector functions.
What are the basic operations in vector analysis?
The basic operations in vector analysis include addition, subtraction, scalar multiplication, dot product, and cross product. These operations allow us to combine and manipulate vectors to obtain useful information about physical quantities such as velocity, acceleration, and forces.
What is the significance of vector analysis in physics?
Vector analysis is essential in physics as it provides a mathematical framework for describing and analyzing physical phenomena. It is used to represent quantities such as displacement, velocity, acceleration, and force, which are critical in understanding the behavior of objects in motion.
What is a vector field?
A vector field is a mathematical function that assigns a vector to every point in a given space. It is used to represent physical quantities that vary continuously in space, such as gravitational or electric fields. Vector fields can be visualized using arrow diagrams, with the length and direction of the arrows representing the magnitude and direction of the vector at each point.
What are some real-life applications of vector analysis?
Vector analysis has several practical applications in fields such as engineering, physics, and economics. Some examples include analyzing the motion of objects in space, designing electrical circuits, modeling fluid flow, and optimizing financial portfolios. It is also used in computer graphics and animation to create realistic 3D images and animations.
