Is Einstein's elevator different for gravity?
In summary: But you wouldn't say that the electric force was uniform; you would say that the electric force was acting on some of the particles more than others.Similarly, with gravity, you would say that the gravitational force is acting on some of the particles more than others, but you wouldn't say that the gravitational force was uniform.
  • #36
csullens said:
If the elevator is in free fall, wouldn't that violate the equivalence principle if I should show that clocks were ticking off at different rates at different locations in my elevator?
If the elevator is in free fall (and is small enough that tidal effects are negligible - that's the "local" word again - as is the case in all equivalence principle scenarios) the clocks will not tick at different rates. If the elevator is accelerating, then it's not in free fall and the clocks will tick at different rates.
But you shouldn't take my word for it. It is a really good exercise to try calculating the relative tick rates for the two clocks in the acceleration and no-acceleration cases for yourself.
  • #37
csullens said:
on the one hand a force which acts equally on everything is really "not a force at all," but on the other hand it will produce a nonzero proper acceleration and time dilation?
No. I was not describing two different ways of looking at the same "force". I was describing two different possibilities that you appear to me to be conflating:
(1) A "force" that does not produce any proper acceleration at all. This is "really not a force at all", by the same argument that Einstein used to show that gravity is not a force: we can duplicate its effects in an accelerating rocket where, by hypothesis, the "force" is entirely absent.
(2) A force that does produce proper acceleration, but acts on every atom in an object in exactly the same way, so that the distances between the atoms remain the same (Born rigid acceleration), and therefore no stresses or strains appear. An example of this would be a hypothetical object consisting of, for example, two electrons connected by a massless spring, oriented parallel to a constant electric field (for example, somewhere between the plates of a very, very large capacitor). Both electrons would be accelerated equally, so the spring would remain unstretched; but they would still be under nonzero proper acceleration and you could not duplicate the effects in an accelerating rocket where no electric field was present, because there would be time dilation between the two electrons (see below for more on that).
Then the time dilation effect is not present, as I said in an earlier post. There has to be nonzero proper acceleration.
More precisely: if we have two objects, both in free fall (zero proper acceleration), at a constant separation, there will be no time dilation between them. This applies to two objects at rest in a freely falling elevator, or two objects dropped inside a rocket that is accelerating because its engines are firing.
But if we have two objects, both under nonzero proper acceleration, then there will be time dilation between them if they are at different heights (i.e., different positions along the direction of the proper acceleration). This applies to two objects at rest at the top and bottom of an accelerating rocket, or two electrons oriented parallel to a constant electric field as in the huge capacitor I described above.
Likes csullens
  • #38
PeterDonis said:
No, it doesn't; at least, not if we take relativity into account.
Yes, you're right. It only works if we don't take relativity into account, which is another way of concluding that the naive analogy between Newtonian gravitation and classical E&M can't be made to work.
  • #39
I admit, I have no intuitive understanding of why two objects at opposite ends of an accelerating rocket, would experience relative time dilation. I will need to look into that.
  • #40
I'm afraid I don't have the tools to solve that problem in such a way that I would get a different answer for the rocket than I would get for the free falling elevator. Which tells me that I guess I don't know how to approach that problem correctly.
  • #41
The pitt.edu article I linked to earlier has a brief discussion of it, under "Gravitational Slowing of Clocks".
Likes csullens
  • #42
PeterDonis said:
What did the "happiest thought" tell him? It told him that, to understand how to make a relativistic theory of gravity, just looking at free fall wasn't enough, precisely because in free fall, there is no gravity. It's not felt at all. So in order to investigate gravity, we have to look at a scenario where it is felt--or at least where something is felt that has some relationship to gravity. That is what led Einstein to the next step: comparing an accelerating rocket to a room sitting at rest on the surface of the Earth. It was the equivalence between those two cases that started him on the road to GR.
I don't know the historical sequence, but the "happiest thought" does imply relativistic notions of gravity. A freely falling elevator is an inertial frame of reference. So if you aim a beam of light across the elevator, it will travel horizontally. But to an observer outside the elevator, the beam is falling along with the elevator and so follows a curved path. Thus, the "happiest thought" implies the bending of light in a gravitational field.
  • #43
In other words, to an observer who has nonzero proper acceleration.
For observers who have nonzero proper acceleration, i.e., who are at rest in the field, yes. But not for observers who are freely falling in the field. That's why Einstein had to take the next step, to looking at accelerated observers, to start obtaining results about the behavior of gravitational fields.
