Is electron spin uniquely determined?
In summary, if you give an atom with an electron in a certain state, like +1/2, you can measure the spin of its electron to tell if it is in a +1/2 or -1/2 state. However, if you need a spin in a specific state, it can be prepared without too much trouble.
pmennen
If I give you a box, completely empty except for one hydrogen atom, could you theoretically measure the spin of its electron to tell me if it is +1/2 or -1/2? If this can be done, how can it be accomplished (at least in theory). Or if the question is complete nonsense, why is that?
(Sorry for the newb question ... I don't yet know much about quantum mechanics)
~Paul
You can measure the spin, you can predict a probability for the values of the spin but you cannot say with certainty what the spin of the electron is before you measure the system.
If there's nothing else in the system you can however tell with certainty what the spin is after it has been measured, infact it will remain the same as what it was measured as.
Without measuring, however, you can only say that it has 50% chance of being up and 50% of being down
If you take a spin with unknown origin, there is absolutely nothing you can tell about it. If you measure it, you can only get +1/2 or -1/2, but you can do the measurement only once, so you can't say anything about the original state. In fact, if you measured the spin to be in +1/2 state, the only thing you can say with absolute certainty is that it wasn't in a pure -1/2 state, which you pretty much can guess from the start.
However, if you need a spin in precise state, it can be prepared without too much trouble.
So that's because the measurement itself disturbs the spin?
I also have some more questions about the spin property:
1.) Are up and down as different as say an apple and an orange or does it depend on how you are looking at it (i.e. comparing it with something, reference frame, etc.)
2.) Once you measure the spin to be say "up", what could cause it to change? (i.e. bouncing off a wall of the container, shooting it with gamma rays, etc).
3.) What does the experiment look like that we would need to make this measurement (in simple terms) ... unless it is not so simple, in which case just skip it.
4.) If the electron is freed from the hydrogen atom, does it still posses a spin property?
Thanks
~Paul
I wouldn't say the measurment 'disturbs' the spin, once you have measured it, any measurments after will give you the same result
1. Up and down are 'orthogonal' states, this means that they are distinguishable, in that respect they are as different as an apple and an orange.
2. Up and down do depend on how you are looking at it but not in any deep way, up and down usually refer to +1/2 and -1/2 along the z axis, so if you look at it in a rotated frame, someone elses z could be your x, but that's nothing odd.
3. Not a clue
4. Electrons are spin 1/2 particles, it'll always have a spin of 1/2 in some direction when measured.
I think K2 means that you can only observe it once from whatever conditions it existed. Once you measure it, it begins a 'new journey'...however, just letting the electron and atom sit in the box, does not mean it is undisturbed...The very presence of any conatiner, in fact the atom structure itself, affects the 'state' of the particles. The electon cloud,the orbitals, for example, is different in different atoms...you can think of it as being different energy levels for example.
Check out the illustrations here:
http://en.wikipedia.org/wiki/Atomic_orbitals#Orbitals_table
In the real world, stuff is 'disturbed' all the time...it's unavoidable...
Related to Is electron spin uniquely determined?
1. What is electron spin?
Electron spin is a quantum mechanical property of electrons that describes their intrinsic angular momentum. It is one of the fundamental properties of an electron and is always present, regardless of its movement or location.
2. Is electron spin a directional property?
Yes, electron spin can be described as either "spin up" or "spin down" along a particular axis. However, the direction of spin is not determined by the electron's motion or orientation in space, but rather by its inherent quantum state.
3. How is electron spin determined?
Electron spin is determined through experiments that measure the magnetic moment of an electron. This can be done through techniques such as electron spin resonance or Stern-Gerlach experiments. These experiments provide information about the spin state of the electron.
4. Is electron spin uniquely determined?
Yes, electron spin is uniquely determined for each electron. This means that no two electrons can have the same spin state, and it is a fundamental property that distinguishes one electron from another. However, the direction of spin can change if the electron interacts with an external magnetic field.
5. How does electron spin impact the behavior of atoms and molecules?
Electron spin plays a crucial role in determining the chemical and physical properties of atoms and molecules. It determines the magnetic properties of materials and influences the way electrons interact with each other, leading to the formation of chemical bonds. In some cases, the direction of electron spin can also affect the stability and reactivity of molecules.
