Aromal
- 14
Can we convert energy to matter?
Aromal said:Can we convert energy to matter?
DaleSpam said:Energy is a property, not a "thing".
You can convert things with energy (e.g. a pair of photons) into other things with energy (e.g. an electron and positron). Energy doesn't exist by itself, so you cannot simply convert energy (without an accompanying thing) into matter.LastOneStanding said:And that property allows you to produce more matter since particle number isn't conserved in QFT. I don't understand your point.
Yes.BruceW said:typically you are going to have particles becoming other particles. I think this is what DaleSpam means.
Certainly, and you can write E/c=mc, and you can write E/m=c², and you can write mc²/E=1, and any other permutation I may have missed. You can add a constant to both sides, square both sides, do whatever you like. All of the normal rules of math apply.Aromal said:Einstein's Energy Equation E=mc2. Can we write the reverse equation as
m=E/c2 ?
yes. as long as 'm' stands for relativistic mass. In essence, c^2 is just a conversion of units. you can even use natural units where c=1, so that E=m i.e. relativistic mass is just another word for energy.Aromal said:Einstein's Energy Equation E=mc2. Can we write the reverse equation as
m=E/c2 ?
It is related. The formula ##E=m c^2## is the formula for the energy of a system whose momentum, ##p=0##. In other words, it is the energy at rest.zdroide said:Is this the reason we cannot get matter to light speed?
The meaning is the same, that rest energy and mass are equivalent. Two things that were previously thought to be different are instead the same.zdroide said:I would like to see all permutations and the meaning.
No. One example is: a table has some lenght. Can we "convert length in a table?" Of course not. In the same way "a portion of matter has some energy, so we cannot convert energy into matter".Hornbein said:"Can we convert energy to matter" You bet. One example is that when the concentration of energy becomes very high it sort of congeals into an electron-positron pair.
You can do this, but it doesn't change the meaning at all. This is off topic for this thread, if you want to discuss rearrangements of formulas more then please start a new thread. But I don't anticipate that you will get anything interesting since it doesn't change the meaning.zdroide said:Can you transform e=mc^2 and isolate c.
The concept of energy being convertible to matter is based on the equation E=mc², which was proposed by Albert Einstein. This equation suggests that energy and matter are interchangeable and can be converted from one form to another.
Energy can convert to matter through a process known as pair production. This occurs when a high-energy photon, such as a gamma ray, interacts with matter and produces a particle-antiparticle pair (e.g. an electron and a positron).
One major piece of evidence supporting the idea of energy being convertible to matter is the observation of pair production in high-energy particle collisions. This has been confirmed by numerous experiments, including those conducted at the Large Hadron Collider.
While energy can be converted to matter, there are limitations to this process. For example, the amount of energy needed to produce a certain amount of matter is determined by the mass-energy equivalence, as represented by the equation E=mc². Additionally, certain conservation laws must also be followed in the conversion process.
The concept of energy being convertible to matter has practical applications in fields such as nuclear energy and medical imaging. In nuclear reactions, a small amount of matter is converted into a large amount of energy, which can be harnessed for electricity. In medical imaging, positron emission tomography (PET) scans use the conversion of energy to matter to produce images of the body's internal structures.
