- #36
lugita15
- 1,554
- 15
For a photon that is polarized in a particular direction, and you send it through a detector oriented at an angle θ, then the probability it will go through the detector is a sinusoidal function of θ. But for an unpolarized photon, the probability that it goes through a detector is always 50-50 regardless of the angle. And the same is true for entangled photons: if you put one of the entangled photons through a detector, no matter what the angle it will have a 50-50 chance of going through. So even though each of the two photons has a 50-50 chance of going through or not, when you look at their results together you find that they are guaranteed to do the same thing, either both going through or both not going through, if they are detected at the same angle.salvestrom said:The outcome is not 50/50 regardless of angle. During calibration it is firmly established that at 0° all outcomes are 1 and at 90° all outcomes are 0. At 45° all outcomes are 50/50. At 60° the outcome is 75% 0's and 25% 1's.
Again, you're talking about polarized photons, which are irrelevant for this discussion.In a single detector, non-entangled photon experiment the results are sinusoidal.
I'm not sure what you mean by the "deviation from the 0° result". Regardless of whether you're dealing with an ordinary unpolarized photon or an entangled photon, the probability that it goes through the detector is 50% regardless of whether the detector is oriented at 0°, at 60°, or any other angle.At 60° the deviation from the 0° result is 75%. This is the result of a purely localised experiment.
This is all true.Introducing Bob and entangled photons allows us to do something special. We can now know the outcome of two settings for Alice at the same time. Bob can be set to show us what Alice would show at any given angle, such as -30° while Alice can be set to show another set of results at 30°.
No, you're talking about polarized photons. The mystery is not just that there is a 75% probability of a mismatch when the detectors are set 60° apart. The mystery is the contradiction between the following three facts:This is a 60° split and will show a 75% deviation, exactly as you get in a localisied experiment. There is nothing non-local implied about this relationship.
1. The probability that P(0) is different from P(30) is 25%
2. The probability that P(-30) is different from P(0) is 25%
3. The probability that P(-30) is different from P(30) is 75%
(Of course, you can switch -30,0,30 to 0,30,60 if you want, it doesn't make a difference.)
That's true.Alice is effectively showing a deviation from her own potential results, if we could actually record both angles at once purely using her detector.
Well, it could have potentially been explained in that way, but I showed the problems with such an explanation.The only spookyness is in the fact both detectors return pricesly the same results at the same angular setting which could potentially be explained at the point of entanglement.
But the kind of experiment with a polarized photon you're discussing doesn't have anything to do with the phenomenon of entanglement, where any single photon will have a 50-50 chance but when you compare the results of the two entangled photons you get a sinusoidal effect.My argument is solely that non-locality cannot be in inferred because of the 75% deviation over 60°, because that deviation occurs in a purely localisied version of the experiment as well.
