Is evaporation a pure diffusion process?
In summary, the driving force for evaporation is a combination of pressure gradient and heat supply. The pressure gradient between the saturated liquid and the surrounding vapor creates a difference in vapor pressure, but heat is also required for the molecules to have enough energy to escape the liquid's surface. Without sufficient heat supply, the evaporation rate may be limited. Additionally, evaporation is a bi-directional statistical process and cannot be solely modeled using pressure. It also requires energy, which can come from the surrounding gas or the liquid itself. This understanding of evaporation is important in practical applications such as falling drop evaporation, wet bulb temperature measurement, and drying processes.
Yinxiao Li
46
Hey, I have a question for evaporation--What is the real driving reason for evaporation?
I usually believe that it is a pure diffusion process: the saturated pressure of liquid at the liquid vapor interface is higher than the partial pressure of vapor in the ambient, and this pressure difference makes the liquid evaporate.
However, I also know that evaporation absorbs heat. It looks like heat might be another driving force for evaporation. Think about this: although there is some pressure gradient, there is no heat supply to the liquid-vapor interface---then what will happen? The heat supply will limit the evaporation rate?
The heat comes from the surrounding gas. It gets conducted to the interface. It can also come from the liquid.
Chet
Chet
Thanks for your reply. If the pressure gradient is very high, and the surrounding gas (also liquid) does not provide enough heat to the evaporating meniscus, then it could be limited by the heat supply or not?
Well there are certainly important practical applications where the heat transfer has to be considered.
Falling drop evaporation
Measurement of wet bulb temperature
Clothes dryers
Industrial dryers
Etc.
Chet
Temperature is the average kinetic energy of the molecules in the material. Evaporation is a loss of molecules from a liquid surface into the gas. The reverse process of condensation is also continuous. It is the statistical balance between evaporation and condensation that decides the net flow rate.
Molecules diffuse within the gas or liquid as you suggest. It will be the statistically faster molecules with higher energy that are more probable to cross the boundary. Collisions on both sides of the boundary share that energy and spread the statistical probability of transfer. How you model the interface is up to you. You can treat the boundary as a statistical diffusion layer between the solid and the liquid.
This is a bi-directional statistical process. You cannot model the process using pressure alone. For evaporation to exceed condensation you must provide additional energy. A net condensation will release energy and so without an external energy flow, an equilibrium will be reached.
You can have a liquid in high vacuum at low enough temperatures.
Surface tension.
Related to Is evaporation a pure diffusion process?
1. What is evaporation?
Evaporation is the process by which a liquid, such as water, changes from its liquid state to a gas or vapor state. This occurs when the molecules of the liquid gain enough energy to break free from the surface and enter the atmosphere.
2. Is evaporation a pure diffusion process?
Yes, evaporation is considered a pure diffusion process because it involves the random movement of molecules from a high concentration (liquid) to a low concentration (gas) without any external forces.
3. What factors affect the rate of evaporation?
The rate of evaporation is affected by several factors including temperature, humidity, air pressure, surface area, and air flow. Higher temperatures, lower humidity, and increased surface area and air flow can all lead to a faster rate of evaporation.
4. Can evaporation occur at all temperatures?
Yes, evaporation can occur at all temperatures. However, the rate of evaporation is greater at higher temperatures because the molecules have more energy to escape from the liquid and enter the gas phase.
5. How is evaporation different from boiling?
The main difference between evaporation and boiling is the energy source. Evaporation occurs at the surface of a liquid due to an increase in temperature, while boiling occurs throughout the entire liquid due to a rapid increase in temperature and the introduction of external energy, such as heat.
  • Mechanical Engineering
  • Materials and Chemical Engineering
